Winter tires + sports package on 335i?
09-30-2007, 04:58 PM | #1 |
Rep 964
Hey all...
Just curious for those of you with the sports package on the 335i, what rims (size) and winter tires do you guys and gals run through the winter? I'm considering getting the 19" upgrade (Style #230) but I just can't seem to find any 19" winter tires I'm thinking I may have to reconsider the 19" wheel upgrade haha |
09-30-2007, 05:18 PM | #2 |
385
Rep 7,952
check tirerack..
http://www.tirerack.com/tires/Compar...er=19&x=18&y=7 they have various tires available in your fitment. remember to run NON-staggered in winter for best results.
09-30-2007, 05:22 PM | #3 | |
220
Rep 8,375
Drives: Just a car
09-30-2007, 07:53 PM | #5 |
53
Rep 2,384
Drives: W211 E350 4M MkV GTI 987.2 S
Most people go DOWN to 17" for the winter for these reasons:
1. In cold temperature your shocks tend to get stiffer. Going down to 17" helps to soften the effects because of the extra flex offer by the taller sidewalls. 2. Your wheels are more likely to bend or getting damage in the winter because of all of those hard ice and snow ridges you have to driver over and scrape your wheels against, plus potholes and and gaps from heaved pavements your car will fall into at speed. Going down to 17" helps to soften the impacts and may just save your wheels. So to me going UP to 19" does not make a lot of practical sense. Even staying with 18" sounds iffy.
07 E93 335i - Returned at lease end
09 W211 E350 4Matic Avant Garde - Blk/Blk, AMG pkg w/18". Sport Susp. F1 Asym. Debadged. 09 MkV GTI w/Leather & 18" Huffs. F1 Asym 10 987.2 S w/Leather sport seat, Sport Chrono, 19" Carrera S II wheels Last edited by halB; 09-30-2007 at 09:38 PM.. |
09-30-2007, 08:28 PM | #6 |
Evil Dictator
12
Rep 176
Drives: E93 space grey, jade grey int
I'm going to get 19's since I have the tire and rim insurnace so I'm not really worried about the damage!!
09-30-2007, 10:02 PM | #7 |
220
Rep 8,375
Drives: Just a car
but you still have to buy the tires and so far I only found 19" with 265/35/19 with cost over $572 for 2 and 225/40/19 with cost over $480 for 2....OUCH!! And I am not sure 40 profile will work or not.
09-30-2007, 10:35 PM | #8 |
Rep 168
I went with 18'' this year. 225/40/18. Non-RFT Dunlop Sport 3D's.
10-01-2007, 10:15 AM | #11 | |
53
Rep 2,384
My 17" Rials from TireRack fit my E93 with sport. They are 17X8, 30 offset, with Dunlop 3D 225/45-17 runflats.
09 W211 E350 4Matic Avant Garde - Blk/Blk, AMG pkg w/18". Sport Susp. F1 Asym. Debadged. 09 MkV GTI w/Leather & 18" Huffs. F1 Asym 10 987.2 S w/Leather sport seat, Sport Chrono, 19" Carrera S II wheels |
10-01-2007, 10:53 AM | #12 |
47
Rep 1,738
+1. The standard size tires are 17", so it's more than likely some do fit.
2006 325i - Sparkling Graphite
2000 S2000 - New Formula Red 2007 Chev Silverado crew cab Z71 |
10-01-2007, 11:13 AM | #13 | |
Rep 964
I saw the post that ctgazer made with the link to tirerack.com, but those tiresr are 235 wide... would that fit on the rear 19" rim as well? I thought 235 were for 8.5" wide rims... while the 19's in the rear are 9.5" wide I think? so it would have to be at least 255 wide for the tire - at least thats what makes sense in my mind (could be blatantly wrong and off the wall). |
10-01-2007, 11:24 AM | #14 | |
385
Rep 7,952
http://www.bridgestonetire.com/tires...roduct_ID=1113
10-01-2007, 10:48 PM | #15 | |
117
Rep 1,764
There still a lot of myths about winter tires that should have died many years a go….1970 tires design has long gone. It is all about rubber compounds and tread design these days. Another myth is narrow tires provide better traction in snow is just silly but still seems to be believed by those who do no research. There is at least 3 tire manufactures that you can select from and don’t use the Tire Rack for what is available for tire size selection because it grossly incomplete in a lot cases. Orb Last edited by Orb; 10-01-2007 at 11:07 PM.. |
10-01-2007, 11:01 PM | #16 |
Rep 46
I am going to run 19's 245/40VR19 winter tires on all 4 corners, with Miro 19-8.5. Ordering everything through **********s this week. The wheels are M6 reps. Wheels 175 us ea, tires $227 ea less $50 for a set of 4
Tires are Dunlop Wintersport M3's they are on tire rack search by size under performance snow tires. |
10-04-2007, 05:16 PM | #18 |
Rep 57
Drives: 2007 Black Sapphire 335i coupe
well i bought winter set of wheels
too which were 18" because 17" didn't fit so make sure you try them on before anything like before mounting tires BMW recommended 17" too but some wheels don't fit |
10-04-2007, 11:13 PM | #19 |
53
Rep 2,384
That's why I bought from TireRack. They call you to review the whole order and check to make sure everything fits before processing it. They also email you an online survey a week after you receive the order to see whether the guy you talked to gave you good service.
10-04-2007, 11:23 PM | #20 |
Rep 97
I have 225/45-17 Dunlop Wintersport M3 DSST's on 17" OEM rims off a 328 E92 coupe (onto my 335 E90 w/ sport package). I checked the rim and it clears the calipers.
10-04-2007, 11:26 PM | #21 | |
53
Rep 2,384
As I mentioned before, the problem may be in the offset.
10-04-2007, 11:31 PM | #22 | |
Rep 252
