F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30 Mud Flaps Retrofit Kit PDF
ARMA SPEED
      07-15-2013, 08:18 PM   #1
MB330
MB330's Avatar
52
Drives: 330i
2018 BMW 330i  [0.00]
2006 E90 330i  [10.00]
I just received this file today.
Front installation is required only to rotate tires to open space.
Rear - tire off only options.
'06 330i Monaco Blue/Gray/Walnut/ZPP/Navi/CA/AT -->ED 2006
'18 330i Estoril Blue Metallic/cognac/AT/Sport
      08-01-2013, 04:32 PM   #2
BXL4
Drives: 2015 328i Alpine White
Looks like it should be pretty easy but I wonder if English to American translation is still required. One page refers to a lug being formed (but isn't talking about a wheel). Elsewhere, expanding rivets are removed. I've worked with expanding rivets on aircraft before and they had to be drilled out yet the instructions call for them to be unscrewed. Are they speaking of something like a wall anchor perhaps?
Have your completed your installation yet? How did it go?
      08-02-2013, 10:52 AM   #3
MB330
MB330's Avatar
52
Drives: 330i
Only on front wheels, rear required removing wheels and I don't have proper tool for that.
Rivets is plastic and hold in place by plastic pin (about 1mm diameter) inside. You take a screwdriver or something else sharp and push this inside pin more inside and it will go. And then you will be able remove rivets. Install is the same you install rivets first (they came with this pin sticking up) and then use small hammer to push inside pin to the rivets head.
I will made a few pics, when I get home from work.
      08-04-2013, 01:22 PM   #4
MB330
MB330's Avatar
52
Drives: 330i
I don't have new rivets, so I used old one (previously used, that you will removed during installation). Instead of nail it will be a plastic pin.
To remove pin, you have to tip with sharp object on the pin (pic 3) end pin will go inside and relive rivets. New rivets with pin looks like one on Pic 2.
You replaced one with new and with small hummer push pin till he seat with the level of rivets head (pic 3)
      08-08-2013, 12:20 AM   #5
BXL4
NOW it all makes sense. Thanks for the pics.
      02-18-2014, 08:27 AM   #6
S4NoMore
S4NoMore's Avatar
Drives: 16 340i, 15 X3d, 91 318i
2016 BMW 340i  [0.00]
2015 BMW X3 28d  [0.00]
1991 BMW 318i  [8.66]
Has anyone done this and can comment on the adhesive "seal" that goes against the body? I'm tackling this soon and initially was planning on only running the flaps during winter months, so I'm wondering if the adhesive can be removed from the flaps and a 3M double-stick type solution used after the first use.
      02-18-2014, 01:51 PM   #7
IoWfan
IoWfan's Avatar
United Kingdom
17
Drives: 2013 F31 328i Msport auto
yep, I've fitted mudflaps front & rear to my 328i. (UK forum thread some weeks ago)
The "seal" is a very narrow bit of double-sided sticky foam-type tape. I think it's probably meant to fill any small gaps so that water/grit doesn't creep behind the flap and onto the paintwork. I can't see why you couldn't just pull of the mudflaps if you really wanted to-I doubt the tape would have a very strong hold.
I did not have to remove the rear wheels to get the mudflaps fitted, either... there was sufficient room to use a small socket on the heads of the bolts.
      02-18-2014, 02:01 PM   #8
S4NoMore
S4NoMore's Avatar
That's what I figure. Glad to hear it may be possible without pulling the wheels.
      01-04-2017, 09:35 PM   #9
capt_slow
capt_slow's Avatar
Drives: 2017 F31 328d
I'm reviving this thread from the dead and adding my $0.02. I just pulled my front and rear set off my 2014 F30 and tried to put them on my 2017 F31 M-Sport
  • Never needed to remove the wheels for install
  • Yes, you can reuse them, but you'll need to reapply the double-sided tape. One roll will be just enough for front+rear
  • The double-sided tape comes off the car cleanly, but getting it off the mudflap is a PITA
  • You'll need a couple sets of expanding rivets
  • Rears fit the LCI perfectly
  • Fronts dont work at all for the LCI, the wheel well liner has changed shape and wont fit the front mudflaps. Even the BMW parts database says it wont fit cars built after 7/2015
Does anyone know if BMW makes mudflaps for LCI cars?
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World
      01-05-2017, 06:15 AM   #10
kzg1969
kzg1969's Avatar
Scotland
1299
Drives: X3M Comp / M3 E93
wish I had seen this tip for not taking the backing off the mudflaps adhesive tape BEFORE I fitted mine!!
I just fitted a set to a F31 Msport....fitted fine. UK car so wonder if there is a difference?
      01-05-2017, 09:28 AM   #11
capt_slow
capt_slow's Avatar
Is your F31 is a newer car? Do you have the part number for the fronts? Mine is 82 16 2 218 983
      01-05-2017, 10:04 PM   #12
John in VA
996
Drives: 2015 228i M Sport
You part # appears to be for F30 variants, but only on F31 & F31 LCI touring models. I've read elsewhere of the rocker panel/molding not allowing a good fit on some models (like M-sport), although realoem "says" they should be the correct part:
For vehicles with M Sports package and M Aerodynamics package
01 Set mud flaps, front F30/F31 82162218983
02 Set mud flaps, rear F30/F31 82162218984
http://www.realoem.com/bmw/enUS/part...%0982162218983
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining
JDAURIA726.00
      01-06-2017, 06:28 AM   #13
kzg1969
kzg1969's Avatar
Scotland
1299
I ordered off Amazon - hope this works
BMW Genuine Mud Flaps Guards Set Rear F30/F31 3 Series (82 16 2 218 984)
https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1
BMW Genuine Mud Flaps Guards Set Front F30/F31 3 Series (82 16 2 218 983)
      01-06-2017, 06:29 AM   #14
kzg1969
kzg1969's Avatar
Scotland
1299
yep that's them - see above post. Sep 2016 Car.
      01-06-2017, 10:47 PM   #15
capt_slow
capt_slow's Avatar
Thats the exact part I have. No idea why it's fitting some cars. Maybe BMW has a new design, but kept the old part number?
      01-07-2017, 01:46 AM   #16
kzg1969
kzg1969's Avatar
Scotland
1299
have you got a pic of your mudflap? i can then compare with mine if you want
      01-07-2017, 06:55 PM   #17
capt_slow
capt_slow's Avatar
Yup! Here it is. I also tried to depict where the fitment issues are
Last edited by capt_slow; 01-11-2022 at 12:57 AM.. Reason: Fixed broken image links
      01-08-2017, 03:39 AM   #18
kzg1969
kzg1969's Avatar
Scotland
1299
yeah, your liner looks different
but then so does your bracket on the MudFlap
      01-13-2017, 10:09 AM   #19
B5A6F30
Drives: 328xi
capt_slow What did you end up doing? Having the same issue with my 2016 F30 Xdrive with the tab being short.
      04-23-2017, 12:36 PM   #20
tsn
Drives: BMW
Do you need a bracket for the left back one? Because of the exhaust there is nothing to mount the two botton screews in.
      11-25-2017, 02:12 PM   #21
sweetboy02125
Drives: BMW 320i
a Shop did these $90 for me this morning
f30post
