Ohlins fit on 335is???
07-03-2013, 08:55 PM | #2 |
Rep 236
Can't comment on coilovers but I went for the Dinan stage 2 upgrade and couldn't be happier. Got the right balance with a slight drop in the front and the car handles much better in the corners.
2011 TiAg 335is -->2015 Range Rover Sport
07-04-2013, 12:37 AM | #3 | |
Rep 24
And how do you like the stage engine tune? worth the money? Dinan stage 2 engine tune together with the intercooler and oil cooler mod is quite a money. ZYZ |
07-04-2013, 03:23 AM | #4 |
624
Rep 3,200
Drives: E92 325i MSport Coupe
Yes Ohlins R&T fits any E9X 3-series...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
07-04-2013, 07:11 AM | #5 |
Rep 236
Stage 2 includes progressive springs, stiffer front sway bar and new rear shock mounts to increase travel. Drops the front about 1/2" which matches the rear perfectly. Really flat in the corners and seems less harsh than stock.
I'm running the Dinan FMIC and oil cooler but a COBB eTune by pro tuning freaks. Really brought the IS to another level in terms of fun.
07-04-2013, 07:23 AM | #6 |
Rep 865
Drives: BMW X3 35i, Porsche Macan S
I'm super happy with my Ohlins. Transforms the car without any harsh ride characteristics. Highly recommended! And stay away from Dinan engine tunes for 335is. Search and you will find many problems. Go with Cobb or JB4.
MOTIV 750 ST | MOTIV PI | 100% E85 | Fuel-it Stage 4 LPFP | MOTIV Boost Box + MHD Protune | Quaife | Öhlins | Brembo | Akrapovic
07-04-2013, 11:03 AM | #7 | |
Rep 24
ZYZ |
07-04-2013, 12:22 PM | #8 |
Rep 865
Don't mean to hijack thread but be careful with Dinan products. I have nothing against all Dinan products in fact I have their CAI and love it. But it is a fact that Dinan products are way over priced compared to other vendors. Only reason to go with Dinan is their warranty which gives some people comfort.
I had Dinan stage 2 tune for a few months and it worked fine for me but cost almost $2,000. Cobb is so much better if you want a Flash tune and costs less than half of Dinan. JB4 is even cheaper than Cobb and has great features. Go with Cobb or JB4 most everyone agrees with this. I removed my Dinan tune and never looked back. Dinan is simply an inferior tuning solution. And Dinan has been unable to fix problems with 335is installations. Unless you track your car you do not need upgraded oil cooler. If you do want to upgrade anyway then go with ER oil cooler not Dinan. FMIC is another story you can definitely benefit by upgrading. Once again Dinan costs twice as much for their Oil Cooler and their FMIC compared to solutions from other vendors of equal or better quality. See a pattern with Dinan?
07-05-2013, 12:33 AM | #9 | |
Rep 24
ohhhh, seems quite a bit people dislike Dinan here. Anyway I won't choose Dinan cuz it cost simply too much and all other tune-ups are way cheaper and seemed not bad according to their specs. I think I might prefer Cobb cuz it seems easy to use. While I just start to look into tune cars and I need more knowledge and exp for engine tunes..... I just change the coilover and looking for brake options (gosh they are expensive). ZYZ |
07-05-2013, 06:02 AM | #10 |
1254
Rep 4,088
What are your suspension goals? Ohlins in particular is quite a performance oriented option and isn't the best solution for "just lowering" if that's what you are looking for. Tell us more.
07-05-2013, 08:56 AM | #11 | |
Rep 1,160
Dinan is attractive to those who don't know better. Their suspension kits for instance use stock rubber bushings, stock suspension arms, stock rear subframe bushings....you get the idea. A turd. You'll be much happier with Eibach Sports and Yellows. Happier yet with M arms, using Delrin. Ecstatic with a Wavetrac LSD. Transcendent with M rear subframe bushings and M sways. Dinan tune? Don't bother. Can't remove & resell - once bought, your cash is permanently gone along with your stock tune. Inferior to, yet much more expensive than, the best popular tunes. They do, however, have a badge. A company that exists for poseurs, you get: A pot metal badge that says DINAN. But only if you spend a minimum of many thousand$. See, you have to "earn" the Dinan badge. Easy to spend $20k there. Falls short of $7500 wisely spent elsewhere. Way, way short. Wow. . Last edited by CALWATERBOY; 07-06-2013 at 01:06 PM.. |
07-05-2013, 09:21 AM | #12 |
Rep 24
07-05-2013, 09:22 AM | #14 |
Rep 24
just for performance needs xD. maybe I can refer to some of your options...
07-05-2013, 09:30 AM | #15 |
Rep 24
07-05-2013, 06:52 PM | #16 | |
Rep 236
07-06-2013, 01:01 AM | #17 | |
Rep 24
ZYZ |
07-06-2013, 07:43 AM | #18 |
Rep 236
COBB is the manufacturer of the AP (access port) that comes preloaded with some OTS (off the shelf) maps depending on your mods and octane availability. The OTS maps are great, but may be too conservative for some...or overly agressive for others. Pro-tuning freaks (PTF) uses the access port to fine tune a map specifically for your car and wants. I wanted great throttle response, with strong predicatable power and they delivered in spades. Really delivered a fast, great driving car. If I was doing it again, I'd just buy the COBB AP from PTF with an included eTune map. Would have saved a couple of hundred over buying separately from different vendors.
As others have stated above, I chose to stay away from the Dinan tune. Can't talk from personal experience but quite a few guys switched from DINAN to COBB and never looked back. Probably a great a tune, I just chose the COBB route instead. That's my opinion from my experiences...but there are a lot of opinions on this site!
07-06-2013, 02:43 PM | #19 |
Rep 199
With the Ohlins on my car I sit 1/4" above my previous height with the M-Sport suspension and everything about the ride is better and the handling is superior.
Drove down to HP Autowerks in Santa Barbara for the install and then home on the Ohlins. Night and day difference. It is much firmer but the jolts from impacts are softened.
2011 335D
07-06-2013, 04:13 PM | #20 |
624
Rep 3,200
To be fair, they ride that high because whoever fitted them for you set them at that height. Ohlins are height-adjustable, so they could just as easily have been set 1/4" lower than the M-Sport than above...
07-06-2013, 10:58 PM | #21 |
Rep 199
Exactly, and it is what I asked for.
2011 335D
