Help==(
03-05-2013, 04:56 PM | #1 |
Just to sweet
20
Rep 249
Help==(
I went to the dealer with wastgate ratle and they told me its the wastegate actuator which i believe. but their saying its not covered under the 8 years 82k extended warranty anyone have any input on that. help please===
03-05-2013, 10:50 PM | #4 |
Rep 1,271
I had mine go in and they said they had to replace the actuators first under warranty before touching the turbos. Then they ended up just replacing both turbos. I was at 81k miles. Go to a different dealer or call bmwna and ask for clarification.
2007 335i Jet Black e92 6AT - VRSF Full street exhaust DP, Chargepipe 7.5 FMIC, MHD, XHP, Koni orange/Eibachs, some other stuff
2007 335i Jet Black e90 6MT - Eibachs, magnaflow exhaust, carbon hood, short shift kit, some other random stuff - being sold somewhere sometime soon probably 2010 335i AW e90 6 AT Msport - The GF took this one over... JB4, PE exhaust, Koni yellows/Eibachs, pink badges, fuzzy steering wheel cover ? |
03-05-2013, 11:13 PM | #6 |
107
Rep 400
Sounds like my dealer. Bunch of assholes.
08 E92 335XI - Space Grey/Coral Red 11.80 @ 118.95mph - 470AWHP
2013 BMW 335XI MSport Alpine White/Venetian Beige 2018 WRX STi TypeRA 2022 X5 MSport Alpine White/Tartufo Merino - Inbound |
03-06-2013, 02:49 AM | #10 |
Rep 288
SI B01 02 12
N54 Engine Turbocharger (Wastegates Only): Emissions Warranty Extension to 8 Years/82,000 Miles E90, E92, E93 (MY 2007, 2008, 2009, 2010): 335i including xDrive BMW NA has agreed to extend, to a total of 8 years or 82,000 miles, whichever comes first, the emissions warranties covering the Settlement Class Members’ vehicles for any failure of a turbocharger caused by a defect in a turbocharger wastegate A slight rattle noise is considered normal operation of the mechanical wastegate valve and is not a failure of the part. No repair should be attempted for this type of rattling complaint. If the noise is described as a clanking noise occurring up to six or seven times in a row during a deceleration from approximately 3,500 RPM, or during a heavy application of the accelerator without a drive gear being engaged, then continue with the procedures described in this document. The existing warranty coverage for all other parts has not changed. ...... if they consider the actuator part of the wastegate, then yes it is covered, but only if they consider it part of the wastegate also, any aftermarket software or hardware controlling or modifying boost pressure will void the extended warranty |
03-06-2013, 11:06 AM | #13 |
Joint Chiefs of Staff
4927
Rep 116,006
03-06-2013, 11:18 AM | #14 |
Just to sweet
20
Rep 249
ill be sticking my boot up their ass when i go up there today--this is insane istead of having it covered under warranty they trow me for a loop and bring this bs on me.
03-06-2013, 12:27 PM | #15 | |
Stupid Idiot
134
Rep 827
The extended turbo warranty covers turbocharger replacement, if needed. The actuator replacement/ adjustment would be a different story. If there is mechanical wear in the actual wastegate valve that is causing boost issues, that would be covered. The issue is that the turbos need to be removed to properly measure the wastegate wear. I doubt the dealership is going to do that unless you agree to pay the labor if no turbo replacement is needed. Sure, the dealer could bullshit BMW and just give you new turbos. That isn't really fair, either.
03-06-2013, 10:47 PM | #16 | |
Just to sweet
20
Rep 249
agreed.but 3gs for $100 worth of parts to be installed is kind of insane for any bmw owner to pay. |
