F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > LED Reverse Light... Anyone have some installed?
Studio RSR
      02-11-2013, 01:23 AM   #1
UhhItsANT
Drives: 2013 BMW 335i
2013 BMW 335i  [0.00]
I am interested in changing out the reverse lights to high power LEDs. Have anyone done this?
First bmw, and haven't touch any of the leds and light stuff. Not to familiar with the error free stuff. Also would a high power 5w LED reverse light be too hot for the reverse housing. I have high power reverse in all the other cars its so nice and bright when i back up.
      02-12-2013, 11:52 PM   #2
UhhItsANT
bump
      02-13-2013, 12:40 PM   #3
Chris@codemybimmer
Chris@codemybimmer's Avatar
171
Drives: AW F30 328i Xdrive
I have a set of 7watts comng in ill let you know how it goes
had 7 watts in my E90 and it was totally fine
      02-13-2013, 02:46 PM   #4
UhhItsANT
Didnt get a response... so i order a 5w cree one on ebay. afraid 7w might be too hot so i went 5.
      02-14-2013, 11:10 AM   #5
UndergroundEuros
41
Drives: 335I Alphina White
7W wont get hot to melt, leds dont get hot enough to damage anything. We have some if any one needs pm us.
      02-14-2013, 06:05 PM   #6
UhhItsANT
wish i knew 7w didnt before i ordered... i'll try out the 5w when they come, if not bright like how i want i'll let you know.
ps, is it easy to replace? if i bring car in for service do I need to put back the original one?
Thanks.
      02-16-2013, 01:16 AM   #7
UhhItsANT
Can you link me to the one you bought? Thanks.
      02-21-2013, 07:07 PM   #8
Chris@codemybimmer
171
i just got mine in today.
works like a charm and no errors.
these are the ones i got
http://www.ebay.com/itm/High-Power-W...:B:SHOP:US:101
ill try to get a picture of it later..since i cant engage reverse gear while the car is off like most traditional cars i cant exactly take a picture of it
      02-21-2013, 07:10 PM   #9
Chris@codemybimmer
171
CREE leds get extremely hot thats why they have heatsinks on them.
its not the LED that gets hot its the transformer.
CREE LED's are known to melt themselves if left on for too long without proper cooling.
      02-24-2013, 10:38 AM   #10
UhhItsANT
Does your flicker. Mine came and I installed it and they flicker when I start the car and also randomly while driving. Looking to get some that don't flicker. The ones I got said error free also.
Here's a link to how it flickers on the car. http://youtu.be/RAZ0plYOr5A
      02-24-2013, 10:40 AM   #11
UhhItsANT
Please check post above. Also how much are your p21s for the f30? Shipped to Berkeley Ca 94710. I'm guaranteed of no flickering?
      02-25-2013, 10:57 PM   #12
Chris@codemybimmer
171
Yup mine flicker. flickered in my E90 so i didnt expect it to not flicker in and F30 as well.
Thats your error check working. It passes a small current though the bulb and checks if theres a voltage difference. if there isnt it assumes that the bulb does not work and will give you an error code.
because the LED bulbs use so little current, it will flicker during error check process.
      02-25-2013, 11:20 PM   #13
UhhItsANT
ok i understand that part... but mine flickers while driving too... i was on 45 mile drive, friend drove behind me he said he flickered randomly throughout the drive. You might want to get someone to check if your flicker while driving. Or maybe leave car running for a while and see if it does.
      02-26-2013, 11:47 AM   #14
Chris@codemybimmer
171
Mine flickers like that too
light checking happens constantly in our cars
only way to fix it is to disable light check through coding
      02-26-2013, 12:55 PM   #15
UhhItsANT
ahhhh that sucks then... i want led reverse light. but i dont want it flicker while driving around. some cities i go to are strict...
do you happen to know how to disable light check through coding?
      02-26-2013, 10:25 PM   #16
Chris@codemybimmer
171
i know that you can
but i dont know which one turns it off
its under FEM_BODY if you have any local coders they can have a look for you
but there's a lot of parameters in there.
f30post
