Which tire monitoring system on '07 e90's?
08-20-2007, 11:09 PM | #1 |
Rep 55
Hi,
I've searched on the board and in this forum and believe that my car has just the normal flat tire monitor (valve stem is flexible black rubber). I'm was trying to get some info from Mike @ **********s and he seems to think that all 2007 e90's use TPMS so I'm getting some conflicting information. Can anyone confirm this for me before I order my wheels? Thanks |
08-21-2007, 11:32 AM | #3 | |
47
Rep 1,738
2006 325i - Sparkling Graphite
2000 S2000 - New Formula Red 2007 Chev Silverado crew cab Z71 |
08-21-2007, 08:41 PM | #5 |
53
Rep 2,384
Drives: W211 E350 4M MkV GTI 987.2 S
I believe the optional 19" rims for 335i come with TPM but they are not functional. The car still uses FTM.
07 E93 335i - Returned at lease end
09 W211 E350 4Matic Avant Garde - Blk/Blk, AMG pkg w/18". Sport Susp. F1 Asym. Debadged. 09 MkV GTI w/Leather & 18" Huffs. F1 Asym 10 987.2 S w/Leather sport seat, Sport Chrono, 19" Carrera S II wheels |
08-22-2007, 08:35 AM | #6 |
Rep 111
Really? My dealer told me I had it but I assumed he was full of sh_t. Is there a way to activate it?
2015 M4
08-22-2007, 08:41 AM | #7 |
385
Rep 7,952
lols..canadian's spec dont use the valve system. they use a monitor that checks the rotational speed which when different, means you have a flat!
08-22-2007, 11:27 AM | #8 |
Rep 111
I think we all know that, but I was questioning what halB said, i.e. that the 230 wheels came with the TPMS valves. Whether true or not, I can't tell. But yes I guess it really doesn't matter in any case...
2015 M4
08-22-2007, 12:50 PM | #9 |
53
Rep 2,384
TPM equipped wheels have thick metal valve stems instead of conventional skinny black rubber ones. Also that the holes on the wheel that the valves fit through seem to be bigger.
So far every Style 230 19" wheels I've seen has that big metal valve stem. I am not sure whether there is actually a TPM inside, or they just put in a thick metal stem to fill up that hole. Regardless of whether there is a TPM inside, your 07 car cannot receive or process the signal because it does not have a TMPS receiver. There is nothing there to activate. It still uses FTM like everybody else in Canada.
09 W211 E350 4Matic Avant Garde - Blk/Blk, AMG pkg w/18". Sport Susp. F1 Asym. Debadged. 09 MkV GTI w/Leather & 18" Huffs. F1 Asym 10 987.2 S w/Leather sport seat, Sport Chrono, 19" Carrera S II wheels Last edited by halB; 08-24-2007 at 10:36 PM.. |
08-23-2007, 03:01 PM | #10 |
Who needs CR7
11
Rep 709
I was told that all Canadian models use the Passive FTM system. which means that the tire pressure is monitor by the ABS system measuring the tire's rotation speed to determine the tire's pressure.
