01-12-2013, 03:15 AM | #1 |
665
Rep 1,980
Drives: 2020 G20 320i M Sport
Trying to make Tails DRLs but only outer tails are lighting up
I can't seem to get my inner tail lights to come on as DRL and I have made the following changes:
REM 01 LceLampMapping1 MAPPING TAGFAHRL H L OUTPUT from off to s1_1 REM 01 LceLampMapping1 MAPPING TAGFAHRL H R OUTPUT from off to ls_r MAPPING UNIVERSAL 6 OUTPUT s1_2_l MAPPING UNIVERSAL 7 OUTPUT sl_2_r Anyone have any ideas? I got these directly off the cheatsheet. |
01-12-2013, 03:58 AM | #2 | |
Rep 145
Drives: F30 320ed
Mine did this after the dealer update and I was able to get them to light up again by changing the PWM levels as for some reason after the update they are switched off. MAPPING_UNIVERSAL_6_PWM_LEVEL_1 (change to werte 64 this is 100%) MAPPING_UNIVERSAL_7_PWM_LEVEL_1 (change to werte 64 this is 100%) Also reported working by doing this: MAPPING_TAGFAHRL_H2_L_OUTPUT (sl_2_l) MAPPING_TAGFAHRL_H2_R_OUTPUT (sl_2_r) |
01-12-2013, 10:41 AM | #3 |
665
Rep 1,980
Thanks! First set of lines you gave me worked.
01-12-2013, 07:37 PM | #4 |
Rep 941
Thanks demge01. I had the same problem after the dealer update and setting the PWM levels worked.
2015 F15 X5 25d Space Gray | Pure Excellence | Dakota Leather/Brushed Aluminium | Anthracite Head Liner | Fender Flares | Connected Drive + Real Time Traffic
2012 F30 335i Sapphire Black 2006 E92 325i Titan Silver 2000 E46 318i Cosmos Black |
