M-ASK II eq
01-04-2013, 03:18 AM | #1 |
Rep 14
M-ASK II eq
I have a '09 car with basic audio and Business Nav, which means I had the six horrible basic speakers, but powered by the 4x40w M-ASK II head unit.
Does anyone know if the speaker output of the M-ASK is EQ-ed like the basic radio or flat like the hifi head unit? And are the rear channels high passed or band passed? Thanks! |
01-04-2013, 06:17 AM | #2 | |
889
Rep 9,097
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
01-07-2013, 07:48 AM | #4 | |
2309
Rep 13,018
01-07-2013, 07:55 AM | #5 |
Rep 14
Thanks a lot, Technic! I guess that means that it'll be possible to recode it to Professional, to get balanced, unEQed signal. But if I'm going to add a MS-8 either way, do you think I'll be able to hear any difference in sound quality after the recode at all?
01-07-2013, 08:30 AM | #6 | |
2309
Rep 13,018
I have noticed a noticeable degradation in sound quality if you Input Setup HiFi signals -obviously for the reasons stated above, it is completely unnecessary. |
01-07-2013, 09:09 AM | #7 | |
Rep 1,319
2016 F80 M3 BSM with Black interior DCT/Driver Assistance/Executive/LEDs/Adaptive/Black Wheels
2014 F32 435i xDrive AW/CR 2014 F25 X3 M-Sport Carbon Black 2011 e92 335is 2007 X3 122k miles 2006 e90 330i 132k miles |
01-07-2013, 09:31 AM | #8 | |
2309
Rep 13,018
You will be changing a great flat, full, low level signal if you do not skip Input Setup. In other words, code to HiFi and then Skip Input Setup. You will have to use the RCA inputs. |
01-07-2013, 09:34 AM | #9 |
Rep 14
01-07-2013, 10:04 AM | #10 |
2309
Rep 13,018
They should know if they do coding... either add #676 to the VO and program car, or go directly to the MASK unit and change variable "audio system" to "HiFi".
01-07-2013, 12:22 PM | #11 | |
Rep 1,319
My X3 has the hifi set up and I used your harness (which was great BTW) to connect JL XD600/6, and with BSW speakers and SWS it sounds pretty decent.
01-07-2013, 02:40 PM | #12 |
Rep 217
What T is saying is that you only need to run the MS-8's Input Setup if you're using the speaker outputs from an HU that has not been recoded to HiFi. If you run the InputSetup using the low-level outputs from an HU recoded to HiFi, the sound will be degraded.
01-07-2013, 08:01 PM | #13 |
Rep 1,319
So if RCA input is used on ms-8 the sound quality won't be degraded? Sorry just want to make sure I am clear..
01-08-2013, 08:25 AM | #14 |
Rep 14
As far as I understand, that's correct. Remeber to skip Input Config. Just be 100% sure that your HU outputs line level, so you don't feed the line level inputs to the MS-8 speakerlevel signals!
