L7 underseat woofers in base audio
11-16-2012, 09:51 AM | #1 |
Rep 13
Does anyone know if the L7 underseat woofers could be powered by the professional HU with base (6 speaker) audio until I get around to purchasing an amplifier?
11-16-2012, 02:46 PM | #2 | |
889
Rep 9,097
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
11-18-2012, 12:23 PM | #3 |
Rep 3
I ve got a stereo system in my e92. I've bought a HIFI subwoofers on ebay. When i've installed them and connect - the woofers worked fine but there was no sound in a front speekers.
Is this normal ? Then i've disconected them and connected the oryginal stereo woofers and all worked fine. Tommorow i'll be installing and alpine retrofit and wondering the wifi woofers will playing good... Last edited by tgorka; 11-18-2012 at 01:05 PM.. |
11-18-2012, 02:52 PM | #5 | |
2309
Rep 13,018
The jumpers connect pin 1 to pin 2, and pin 3 to pin 4 in the OEM connector. |
11-19-2012, 09:49 AM | #7 | |
281
Rep 4,121
Only the stereo woofers are designed to pass the signal back to the vehicle wiring harness (parallel wiring) and into the front doors. You could build an adapter (if this is all you plan on doing) but if you are redoing your system, the "right" answer is to properly crossover your signal from your amp to HP the doors and LP the woofers. |
11-19-2012, 11:04 AM | #9 |
2309
Rep 13,018
11-19-2012, 01:30 PM | #10 |
Rep 13
I haven't purchased it yet. i was looking into a 4 channel alpine amp to power the door speakers and then the underseat woofers.
http://www.crutchfield.com/p_500MRPF...-MRP-F300.html but i'm completely open to suggestions at this point. |
11-19-2012, 01:40 PM | #11 | |
2309
Rep 13,018
11-19-2012, 02:42 PM | #13 |
2309
Rep 13,018
