10-13-2012, 01:55 PM | #1 |
Rep 145
Drives: F30 320ed
Coding: Bluetooth Audio
Had a go with this and thought I'd cracked it but got stuck...
In the HU entry i coded the following: A2DP_PROFILE - aktiv CDMM_BLUETOOTH_AUDIO - aktiv It's greyed out in the Multimedia menu despite all of the above and obviously no music coming through.. Any ideas and advice appreciated. Cheers. Last edited by demge01; 10-21-2012 at 12:47 PM.. Reason: Images Removed. |
10-13-2012, 04:37 PM | #3 |
Rep 94
Sadly it won't work without a COMBOX :-(
Edit: You need the combox to handle the A2DP. Also of note, according to BimmerTech, the Combox's they sell only work with the HU_CIC so it is a $2000 upgrade :-( |
10-13-2012, 04:50 PM | #4 | |
Rep 145
Drives: F30 320ed
Its odd how the Bluetooth works perfectly for handling phonecalls, data and contacts etc but can't handle audio without a combox. Cheers. |
10-13-2012, 04:52 PM | #5 |
Rep 94
No problem, I am going to try to source an OEM new COMBOX media for my car spec soon. I will let you know what happens. It is definitely possible to do it. I am also going to have to find the wiring from somewhere..
10-13-2012, 08:07 PM | #7 |
Rep 94
10-13-2012, 08:10 PM | #8 |
Rep 383
Not mine- I enabled bmw live and internet to show up in the menu, however, it says to please activate data services over bluetooth. I can't figure that part out... In my bluetooth settings, only office, telephone, show pictures, shows up.
10-14-2012, 03:58 PM | #10 |
Rep 145
Drives: F30 320ed
10-14-2012, 10:43 PM | #12 |
54
Rep 1,544
If u don't mind losing satellite radio u can always order a EU/ROW-spec radio professional headunit which is compatible with either 6NK/NL.
10-15-2012, 02:06 PM | #13 |
Rep 23
11-08-2012, 07:40 AM | #14 |
Rep 22
I think you have to set up a tether from your phone.
04-12-2013, 08:10 PM | #15 | |
665
Rep 1,980
Drives: 2020 G20 320i M Sport
Have you had any luck with it? I get BMW Live and Internet but I have no bluetooth data transfer profile on my options. |
05-04-2013, 12:52 PM | #16 |
Rep 286
Aritaurus, To enable BT Data, You need to code one more function.
HU_CIC or HU_ENTRY 3003 - Funktionen - BT_DATA_SERVICE - Aktiv. Then FDL Code. If it doesn't show up after FDL Code, Do FDL Code again and then you should see it. You might have to repair your phone again. |
