RF 3sixty.3 wiring Q
09-02-2012, 06:05 PM | #1 |
Rep 4
Hi ive been using this forum as a guideline for things i need to know,
but at this point i can not find what im looking for im going to hook up a RF 360.3 to my e90 hifi, (making my own WH ,no offense Technic since i like to do things myself) the current setup is Gladen zero 100 for the fronts, earthquake sws8 2ohm under seats, and a gladen sql 15 inch in the trunk powerd by mac audio Fearless D 2200 Amp for the front and under seats ar 5 ch RF amp, my question´s is what wires from the HU should i use for the front, underseats etc, may be a dumb question, but this is my first car audio build and i want it to be good =D my first tought was to wire straight after oem amp but after reading i won´t do that, but then i had no clue how to wire it up. hoping for some help on this thing ill post upp some photos here when i get going on the install Best Regards Kriss |
09-02-2012, 06:23 PM | #2 |
300
Rep 3,969
Hi,
you have HiFi, so please use the pre-amp signal(s), which is balanced, differential, low-level (5V). Use only FL & FR if you have no PDC (park distance control) or use FL, FR, RL & RR if you do have PDC.
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
09-02-2012, 06:29 PM | #3 |
Rep 4
3sixty.3
hi, and thanks for the quick reply,
i have pdc so ill then use all the wires, but im a bit confused how those 4 channel from the HU could go out to 6 ch, so there is a function in the 3sixty that can take the same innput and make 2 diffrent output setups ? Best regards Kriss |
09-02-2012, 06:45 PM | #4 |
300
Rep 3,969
The HU outputs are full-range. The 3sixty sums the inputs into two channels, then splits the signal however you tell it to, up to 8 channels. I think you need to read the manual!
09-02-2012, 06:50 PM | #5 |
Rep 4
thank you for the help kaigoss69
going full at it in the manual then. anyone know of any good guides or something about tuning the Eq and crossovers etc? Best Regards Kriss |
09-03-2012, 12:55 PM | #6 | |
221
Rep 2,339
Even after fooling around with car audio system for over 10 years, the first time I tried to install a DSP, I was overwhelmed with trying to tune it and I needed the help of an experienced friend to teach me how to use it properly.
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
09-03-2012, 05:27 PM | #7 |
Rep 4
thanks for the reply
i might try to find somebody local, or even hunt down the tuner of the EMMA winner cars (eu car sound comp) ive heard alot of talk with the 3sixty about the auto tune and then fine tune it afterwards? |
