driving on nice mountain road
06-27-2012, 12:26 AM | #1 |
Rep 109
I will be driving on a nice mountain road with nice twists and turns.. I've driven on this mountain 3 times.. twice on my BMW and once on my Mustang. Both times I've driven on the BMW i didn't bother to turn off DSC. This time around I plan on turning it off but I'm not that confident yet. Would you recommend it? Will the drive be more fun with it turned off? Its one lane each. One going up then one going back. Lanes are fairly wide, probably will fit 1 and a half 3 series in terms of width.
06-27-2012, 12:31 AM | #2 |
93
Rep 1,644
if your in a 328 you can turn it off all you want, ur not going to lose control. in a 335i a whole other story. but why not just turn it off halfway and be on the safe side.
06-27-2012, 01:15 AM | #6 | |
Where'd my VTEC go?
481
Rep 6,067
You can most definitely eat it in a 328i. You 335i guys make it seem like the 328i is powered by a lawnmower engine. Even so, there are many ways to lose control other than traction loss from raw power.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
06-27-2012, 03:36 AM | #7 |
93
Rep 1,644
06-27-2012, 03:36 AM | #8 |
93
Rep 1,644
06-27-2012, 03:49 AM | #9 |
4487
Rep 3,873
Drives: '23 G80 M3C xDrive; '13 e92 M3
What road?
I did the snake in my 335is, and I left traction completely on. I still managed to fishtail on a turn. Nothing horrible, and I easily regained control, but I personally want to be more confident with the power at my feet when on a road like that. I'm driving with the traction off (not all the way, just pushing once) all the time now. Seeing how it reacts to sharp turns on the road in high revs and normal revs. It's tough to make the car want to slip, even with traction off, unless you are really trying
2023 G80 M3 Competition xDrive Isle of Man Green on Kyalami Orange full leather - 826M black wheels - Carbon Fiber Trim - Carbon Bucket Seats - Executive/Driving Assist/Parking Packages - Laserlight - M Shadowline Lights - M Drive Pro - CS Trans/Diff/Steering Coding
2013 E92 M3 Mineral White on Bamboo Beige noviello leather (Base w/ Nav, Comfort Access, Lighting Pack) - DINAN Stage 1 and Free Flow Axle-Back Exhaust |
06-27-2012, 04:18 AM | #10 |
Rep 642
OP...
I would consider a few things. 1. You mention you are not confident. I would certainly keep it on in that case. 2. The DSC in our cars is fairly un-intrusive other than traction issues coming out of corners where it seems more proactive. I drive very hard on twisty mountain roads that I know SUPER well...I leave it on, but it has only intervened twice. Once, I didn't need it, the other time, I probably did. So to me it's an insurance policy but it's my job to keep the car within its mechanical limits, and when I get that right, DSC leaves me alone. 3. Drives are always more fun when you and the car come back as they left. If you spend enough time of car forums, you will find enough examples of driver's who have eaten the off-ramps because they wanted to be heroic without tech. So...what I'm saying...is that, in my opinion, if you are doing it right, DSC on or off won't make a difference because the DSC won't intervene. If you are doing it wrong on a mountain road, you probably need te DSC to help out. And finally, DSC doesn't mean you can't crash! |
06-27-2012, 04:25 AM | #11 | |
4487
Rep 3,873
I've yet to encounter this with my BMW and actually barely see a difference between DSC on vs off. (and find that the handling is hundreds of times better than my G37 sedan was; I couldn't do half the things my car is capable of doing without slipping and/or killing myself in the G/the car just wouldn't let me do them).
06-27-2012, 04:57 AM | #12 | |
Rep 642
For me, I find DSC intervenes mostly on traction issues...however, there is an amazing combination of corners near me...the road rises, crests, then falls into a right after as it rises again into a left hander....You can really get the speeds up on this....so you have a lot of dynamics at work from braking, falling, bottoming, turning, accelerating etc. I've over-cooked this corner joyfully a few times and DSC jumped in...to me it was intuitive and without the yellow flashing light I might not have really felt it...just the slight modulation of the brakes coming through the wheel. At any rate, a tight mountain switchback is not the place to find out what the limits of your car, DSC, or driving ability are! |
06-27-2012, 05:35 AM | #13 | |
4487
Rep 3,873
06-27-2012, 06:41 AM | #14 |
Came to the N55 Darkside
1115
Rep 12,740
Be safe, whatever you do. We don't want to have to read about you on the home page of Bimmerpost any time soon, if you know what I mean.
06-27-2012, 08:04 AM | #15 |
Rep 1,157
if you are wondering how/when dsc will intervene, then leave it on.
you should be able to drive near the limit, and know when this system is going to intervene. if you are driving smoothly you can begin to slide the car and not actually have the system intervene. it is awesome in the wet. being able to drive to the limit and have slight slip angles while having a safety net is pretty awesome. mind you, if you dive into a corner and push the front, or hammer the throttle and lighten the rear, the dsc will rudely intervene. turning the traction control off(well, as off as you can without disabling the whole system) would be, in my opinion, a step in learning your cars limits, and learning balance. |
06-27-2012, 08:08 AM | #16 |
Driver
37
Rep 1,577
06-27-2012, 12:23 PM | #17 |
2051
Rep 25,989
I agree, you should play around with it in an open area so you know how it reacts before turning it off. I've crashed my car up in Angeles Crest off of the 210 freeway. Pushing your car to it's limits when you're not familiar with traction control and how it reacts can make a pretty depressing night.
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
06-27-2012, 12:59 PM | #18 |
Rep 10
It is a safety function that is there for a reason. i haven't found it to be that intrusive in my driving, it's quite difficult to trigger it and when you DO trigger it, you will probably need it..
