must change rotors with break pads?
01-15-2012, 06:01 PM | #1 |
45
Rep 437
I need new rear break pads and I was told I need to replace the rotors as well...is this true? Or can I get by with just replacing the pads and new break sensor? Also, where can I buy the break sensor needed? Sorry never have messed with the breaks on this car before.
01-15-2012, 09:17 PM | #2 |
Rep 1,160
The rotors depends on the thickness of them, i forget the minimum recommended thickness.
www.getbmwparts.com is a great site for oem parts
Monaco Blue 330xi - Terra Interior/6-MT/Sport/Premium/Cold/CSL's/M3 Spoiler Lip/Black Kidney's
01-16-2012, 03:02 PM | #4 |
Rep 1,160
micrometer
01-17-2012, 01:18 PM | #5 |
45
Rep 437
01-18-2012, 05:22 PM | #7 |
549
Rep 5,695
BMW recommends generally a rotor change but not always necessary. Minimum thickness is indicated on the rotor hat. Here is a link for reference:
http://www.e90post.com/forums/showthread.php?t=546064 If not replacing the rotor, a light cut on a lath to remove any lip can help. You can also add a small chamfer to the friction material at top and bottom of the pad to clear the lip until fully bedded if rotor surface is otherwise in good condition. Best solution is to get new pads and smooth/flat rotor surface |
01-19-2012, 08:34 PM | #9 |
Rep 98
i say change everything that way there no pull coming from the rotors later on, ecs tuning sells a package with sensor, rotor and pads
http://www.ecstuning.com/BMW-E90-335...All/ES2083397/
07 Bmw 335xi 07 A4 3.2 quattro |
