2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Marketplace Commercial Marketplace - F10/F11 Classifieds ▀▄ eas | KW Coilovers- Your #1 Source for V1, V2, V3's!
      01-12-2012, 05:48 PM   #1
kevin @ eas
kevin @ eas's Avatar
Drives: 2015 BMW M4
eas is proud to be an authorized KW dealer and supply your BMW's performance suspension needs!
Variant 1
Featuring sporty handling with factory pre-set damping, the KW V1 Coilover system is ideal for customers wishing to rely on the experience of KW's engineers to set the damper setting, yet determine their own degree of lowering. In extensive driving tests KW's engineers have set the dampers for the best balance between sporty driving, comfort and safety. The user is then free to decide the best height setting for their use and preference.
All KW coilovers pass stringent German TUV safety and quality testing standards. Each kit is sold TUV approved.
Features:
-Optimally pre-set
-Sporty harmonious damping technology
-"inox-line" Stainless steel technology
-Individually height-adjustable
-Lowering range approved by the German Technical Control Board (TÜV)
-Fully finished complete solutions
-High-quality component parts for long durability -Comprehensive documentation for easy use
Variant 2
The KW Variant 2 coilover system is intended for the experienced driver who does not only wish to determine the individual lowering of his vehicle, but also wishes to carry out setup adjustments. The adjustable rebound damper allows adjusting the pitch and roll behavior of the vehicle and therefore the driving pleasure can be adapted to the own requirements.
The rebound adjustment can be installed via an adjustment spindle at the piston rod end, as far as it is vehicle-specifically possible. The rebound damping primarily controls pitch and roll of the vehicle, especially in the low speed damping range which directly influences handling and comfort. Therefore vehicle can be adjusted to the needs of the driver, making the ride variable from comfortable to sporty and stiff, both with improved road handling.
Features:
-Damping technology with individually adjustable rebound
-"inox-line" stainless steel technology
-Individually height adjustable
-Adjustment parameters approved by the German Technical Control Board (TÜV)
-High-quality components for long durability
Variant 3
The KW coilover suspension system enables the owner to substantially lower their vehicle while retaining enough travel to handle maximum load and dynamic loads during driving. Variant 3 permits an even higher degree of customization to the suspension. Adjustable (and independent reacting) rebound and compression damping allows a truly individual performance driving setup for those technically demanding drivers. Compression dampening adjustment is conducted in the low-speed range, while the high-speed set-up, so decisive for driving comfort, has been pre set by KW engineers.
Important characteristics such as safety, quality and performance are all taken into consideration with each KW coilover design. Each vehicle application is specifically designed and engineered for a proper range of motion, min/max weight loads and min/max lowering. All these requirements are met while retaining it's performance handling characteristics. Each KW coilover suspension is produced with unique stainless steel "inox-line" technology. The stainless steel construction internally and externally provides long term durability and corrosion resistance from the elements.
Features:
- Independently adjustable damping technology - rebound and compression damping
- "inox-line" stainless steel technology
- Individual height adjustment
- German TUV-tested adjustment parameters
- High-quality components for long life
- Comprehensive documentation for ease of use
- Infinitely adjustable rebound damping
- 14- level adjustable compression damping
- Unique, independently functioning damping power adjustment
*Availibility of Variants depends on Vehicle Make & Model
FREE SHIPPING in the Continental United States.
Ordering:
Phone:
You can reach us directly by calling 866.669.0705 to place your order over the phone.
Payment:
Credit/Debit Cards: Visa, Mastercard, Discover, PayPal, Google Checkout (available online & over phone)
Other Payments:
Money Order/Cashier’s Check & Bank Wire Transfer are also available. Please contact us to pay with either of these methods.
Tax:
All CA customers will be charged 7.75% CA Sales tax.
Shipping:
All orders will be shipping via UPS. If you are interested in shipping to Hawaii, Alaska, or internationally, please contact us directly, as you will be charged additional shipping fees.
Hours of Operations:
Monday - Friday from 9AM to 5PM PST
Saturday/Sunday - Closed
Retail Location/ Installation Center:
Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell.
Contact Info:
Phone: 866.669.0705 x31
Email: kevin@europeanautosource.com
Website: http://www.europeanautosource.com
Feel free to contact me via PM, email, or phone if you have any questions.
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      01-25-2012, 06:50 PM   #2
kevin @ eas
Drives: 2015 BMW M4
Thanks for the inquires. Come get your set installed or shipped today!!
      01-25-2012, 08:03 PM   #3
bobblehead
bobblehead's Avatar
256
Drives: warp speed
None of the above is applicable for the xdrive. Am I correct ?
      01-26-2012, 01:55 PM   #4
kevin @ eas
Drives: 2015 BMW M4
Unfortunately, I just checked and they do not work with the X Drive.
      01-26-2012, 03:04 PM   #5
bobblehead
bobblehead's Avatar
256
Drives: warp speed
I know, KW has been testing their Variants since Spring 2011 and the latest info I have is they are still at least 6 months away from any firmed production date.
By that time, I am ready to get another new car.
      02-02-2012, 05:38 PM   #6
kevin @ eas
Drives: 2015 BMW M4
Orders shipping out daily. Get your KW coilovers today!!
      02-04-2012, 09:04 AM   #7
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
Are there any other (not listed above) limitation/quality differences of the V1, vs the V3? I'm not planning on tracking my vehicle, but I do like curves and a low stance. I would rather KW pre-set the damping, but I don't want to miss out on any other "gotchas" by going with the V1.
      02-20-2012, 06:55 PM   #8
robert @ eas
310
Drives: BMW
The next one to ship could be yours! CALL US to set up your order
Robert T. | european auto source (eas)
email: robert@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x21
      03-20-2012, 04:44 PM   #9
EAS
EAS's Avatar
548
Drives: VF620 M3
Thanks for the order Dom, I hope you enjoy your new KW coilovers!
      04-25-2012, 06:36 PM   #10
robert @ eas
310
Drives: BMW
Call us to order your KW today!
      05-04-2012, 04:42 PM   #11
robert @ eas
310
Drives: BMW
Call eas to order your KW Suspension
      05-11-2012, 03:21 PM   #12
kevin @ eas
Drives: 2015 BMW M4
Call today to get your KW's!! Order shipping out daily!
      05-18-2012, 04:14 PM   #13
robert @ eas
310
Drives: BMW
Get your KW Coilover Suspension now!
Call eas to order
      05-25-2012, 04:36 PM   #14
kevin @ eas
Drives: 2015 BMW M4
Thanks for the inquiries!! Get your KW's today!!
      06-01-2012, 03:08 PM   #15
kevin @ eas
Drives: 2015 BMW M4
      06-08-2012, 05:49 PM   #16
kevin @ eas
Drives: 2015 BMW M4
Thanks for the inquiries!! Get your KW coil overs today!!
      06-27-2012, 06:21 PM   #17
kevin @ eas
Drives: 2015 BMW M4
Get you KW coil overs today!! New orders shipping out daily!!
      06-29-2012, 12:13 PM   #18
kevin @ eas
Drives: 2015 BMW M4
Get your KW coil overs today!! PM for special pricing
      07-06-2012, 06:41 PM   #19
robert @ eas
310
Drives: BMW
Call eas today to order your KW Suspension!
      07-09-2012, 07:00 PM   #20
kevin @ eas
Drives: 2015 BMW M4
Thanks for the inquiries!! Order your KW's today!!
      07-10-2012, 01:27 AM   #21
raiderrick
Drives: 535i
2011 f10 with edc i dont track my car just want a nice smooth ride with a lowered stance...i have acs spring on it now...not low enough! how much?
      07-10-2012, 11:12 AM   #22
kevin @ eas
Drives: 2015 BMW M4
PM coming your way!!
5post
