MAF sensor
11-30-2011, 09:52 PM | #1 |
Rep 236
Drives: 335d
MAF sensor
Has anyone tried cleaning the MAF sensor yet? (with cfc sensor cleaner) I did this on my e39 M5 every 20K and it seemed to help the responsiveness of the engine. Or Is this a mute point with the D?
Enjoy what you drive.
12-01-2011, 08:37 AM | #2 |
Rep 79
Have you checked to see if your sensor is dirty? After about 10k miles, mine still looks good as new.
I'd say there's probably no harm in cleaning it either way. |
12-05-2011, 08:33 PM | #3 |
Rep 236
Drives: 335d
Yeah. I've got 43k on the clock now. I think I'll clean it this weekend. I'll post afterwards if I notice a difference.
01-31-2012, 10:26 PM | #6 |
Rep 236
Drives: 335d
Have not got around to doing this yet. Been busy. I will try in the near future and post results.
02-01-2012, 08:48 PM | #7 |
149
Rep 2,383
Not a mute point, unless you can't hear it. Maybe a moot point though....
Speakers: CDT Audio HD-42 comps--front doors (RAAMmat deadened), CDT ES-06 6.5" woofers--kickpanl Pods, Hertz EBX202R dual 8" ported trunk sub. Amps: Phoenix Gold RSd 500.4 (comps & pods). PG RSd 600.1 (sub). Power & Ground: 4AWG Streetwires w/RockFosgt RFDB1 distro blocks. Input: HU lineout--Kicker KISL RCA adapters--RockFosgt RFIT-6 cables--Audiocontrol Matrix--Monster cables--RSd 500.4--lineout Monstr Cabl to RSd 600.1.
02-02-2012, 07:44 PM | #8 |
Rep 236
Drives: 335d
Don't you mean a soot point? Ha ha......
02-04-2012, 02:48 PM | #10 |
149
Rep 2,383
I apologize if my response wasn't sootable.
04-20-2012, 11:22 AM | #11 |
Speed Demon
207
Rep 3,690
Someone post up a pic of the MAF and where it's at. Getting an Air Mass Sensor SES lately, and I need to see if it's just dirty, or if I need to take the car in (and, if anyone knows, is the MAF covered under the emissions warranty?).
Current: '21 M5C, '15 X6 50i Previous: '18 M550i, '16 550i, '11 335is, '09 E93 M3 DCT, '10 E90 335d, '07 E90 328i |
04-21-2012, 08:37 AM | #12 |
73
Rep 1,770
06-19-2013, 04:13 PM | #13 |
614
Rep 2,410
So, this week I started getting a P0101 MAF code. Only at higher engine loads. Using the Torque App I could quantify a ~10-15 hp loss compared to "normal" and lower peak boost readings (it uses the MAF readings to calculate boost). So... something strange was afoot.
Removed the MAF and noticed a small piece of cottonwood pollen clinging to the very middle section of the mesh screen on the air box side that protects the hot film element from debris. I replaced the air filter earlier this spring and perhaps that contaminant found its way in there during the process? Not sure. I removed that from the screen, and since it was already detached, decided to "clean" the sensor with CRC fluid. Sprayed it and the electrical connector, let dry, re-assembled. Cleared code and road tested. No more codes at full fueling and the lost power was back. Since I did two things at once I'm not sure which "fixed" the issue. Question for those with MAF experience: Could the pollen blockage directly in front of the hot film element cause enough turbulence/blockage to the air stream that the MAF reading at higher air utilization was out of whack? Or is it more likely that the CRC cleaning was the more likely cause for the improvement? |
06-19-2013, 04:29 PM | #14 |
96
Rep 1,592
Drives: 2011 335d, M-Sport
@TDIwyse , the other reason for the mesh screen is to more evenly distribute the airflow over the film. A decent sized bit of anything sitting there-on could certainly cause enough turbulence to yeild unstable readings. This coupled with a slightly dirty sensor was your likely culprit. Like you said, though...no way to conclusively determine how much of which was the cause.
06-19-2013, 04:30 PM | #15 | |
Jumping Jack Flash
324
Rep 1,692
Drives: 2021 X3 M40i
2021 X3 M40i: M Sport Differential, Adaptive M Suspension.
Previous BMWs: 1971 BMW 2002, 1973 BMW R75/5, and 2011 BMW 335d Previous Other Vehicles: '67 Cougar, '70 911e, '86 Jetta Diesel, '05 and '12 Foresters, et al. |
06-19-2013, 04:39 PM | #16 |
Speed Demon
207
Rep 3,690
It's just to the right of where the air filter is, into the center of the pipe that funnels the air from the intake to the turbos/engine.
06-19-2013, 05:15 PM | #17 |
96
Rep 1,592
06-20-2013, 07:03 AM | #21 |
614
Rep 2,410
There's 2 Torx bolts (T-30 if my memory is correct) that holds the MAF housing to the air box (and there's a large, thick rubber o-ring at the interface as well) and then a standard metric bolt worm/clamp on the other end of the housing/air duct interface.
06-20-2013, 07:43 AM | #22 |
229
Rep 3,489
Drives: Montego Blue 335d
It is easy to remove, another thing if your running K&N be carefull oil doesnot run thru the piping and gets your MAF otherwise it will render it w/o warranty this happened to me with my 02 MCS I had a K&N look alike and iol messed up my MAF
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now) |
