2010 2011 BMW 5 Series Forum F10 PYSpeed.com | *PRE-ORDER* RS Technik Light Weight Wheel Spacers + FREE KEY Fob Holder |
07-25-2011, 08:30 PM | #1 |
917
Rep 6,094
PYSpeed - RS Technik Wheel Spacers (click for detail)
This is the lightest Wheel Spacer and Best Quality on the Market. - Available Now in 5mm, 12mm ,15mm and 18mm including 10 Matching Extended Wheel Bolts (More Coming Soon!) We are getting a huge shipment of RS Technik Wheel Spacers in Mid-August and we will run a LIMITED QUANTITY PRE-ORDER Special for Forum Member Only. (Every order will get a FREE BMW Leather Quality Key Fob Holder ($28.99 value) to protect your Key Fob. Don't Wait! 1. Order on our web - http://www.pyspeed.com/RS-Technik-Wh...ries-s/795.htm 2. Put FREE KEY FOB Holder Promo and your forum member name in order notes 3. When RS Spacers shipping begins, you will receive a free Key Fob Holder in the package. RS Technik Wheel Spacers (You Deserve The Best) Packages Includes: - (2) RS Technik Wheel Spacers - (10) Extended Wheel Bolts in Anodized Zinc Coating as well **FREE BMW Leather KEY FOB Holder PROMO SPECIAL ($28.99 Value)** Give your BMW an aggressive stance and fine tune its handling characteristics with RS Technik Wheel Spacers. User wheel spacers to optimize your tire track width improving lateral stability and grip. Additionally, spacers give your vehicle a more aggressive look, by filling out the fender gap generally associated with conservative stock wheel offsets and suspension setups. Each spacer is optimized for the ultimate in strength while maintaining the lightest possible weight. Made from T6-6061 aircraft grade aluminum and machine finished to absolute perfect. Each spacer is proudly made in the USA. Features: - Made from 100% billet aircraft grade T6-6061 aluminum. - Finished to last. Anodized zinc coating ensures each spacer is resistant to corrosion, wear and provides a beautiful fit and finish. - Stuck spacers are a thing of the past. Each spacer features a chamfered inside edge that allows easy removal using a standard flat head screw driver. - Design and manufactured specific for your vehicle. Hub-centric design means you get a perfect and safe fitting spacer. - Includes matching corrosion resistant wheel fasteners. Each fastener is made specific to match your selected spacer size. - Made in the USA. Models Supported: - All BMW 5x120 bolt patterns with 72.5mm hub flanges (not E39, E70) Last edited by PYSpeed.com; 07-25-2011 at 08:37 PM.. |
Tags |
5x120 wheel spacer, black bmw wheel spacer, bmw wheel spacer, ultra light wheel spacer |
