Spacer for SWS-8
06-15-2011, 04:14 PM | #2 |
Rep 831
PM forum member JTsherri, he makes these and they're top notch
F31 335d M Sport XD - Mineral Grey - Coral Red - 19" 442M - HK Audio - M Sport Plus Pack - Heated Seats Check out my E90stereo install guide - http://www.e90post.com/forums/showthread.php?t=540954 |
06-16-2011, 03:41 AM | #3 |
No 55mph
1622
Rep 8,477
Actually, he prefers that you email him jtsherri@gmail.com as he doesn't read his PM's very often...
Link to review of his spacers: http://www.e90post.com/forums/showthread.php?t=314849 I have them and they are excellent
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
06-16-2011, 04:35 PM | #5 |
Rep 831
The spacers make fitting the SWS8's simple as you don't need to modify the enclosures. Without these you'd need to file down the plastic fins at the bottom of the enclosures. There's also a spacer to raise the carpet and grill to stop these hitting the speaker cone.
06-16-2011, 04:39 PM | #6 | |
Rep 56
06-17-2011, 12:47 PM | #7 |
Rep 831
I'd speak to your installer and ask them how they usually install them. I would hope that a professional installer would have their own solution but it's worth asking and then deciding what you think's best.
If they use similar then fine, if they are going to butcher your enclosures then it might be worth providing them with a set
06-17-2011, 01:25 PM | #9 |
Rep 831
Out of interest, what are you planning to do with your system? I can see you've got Logic 7 already. Are you just planning on changing out your OE under seats for two SWS8's?
06-17-2011, 01:59 PM | #10 |
Rep 46
I have to change my subwoofers cause one of em is blown already. I will just replace my subs and thats all.
06-17-2011, 02:51 PM | #11 | |
Rep 831
Also I think it's 2 ohms so if it is make sure you get the 2 ohms SWS8 else it will reduce further what you are going to get out of it.
06-17-2011, 03:12 PM | #12 |
300
Rep 3,969
That's not what you said a few days ago. Installing just the SWS-8s will be a mistake. They will not do very well with roughly 30W per channel from the OEM amp. They need at least 100W, better 150W per channel.
Also, there are plenty of DIYs for installing the SWS-8s and it really is not that difficult. Unless you have two left hands, you should do this yourself. There's no tellin' what will happen when the best boys get their hands on it...
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
06-17-2011, 03:17 PM | #13 |
Rep 831
I'd listen to kaigoss69 on this one
