06-09-2011, 10:48 AM | #1 |
1400
Rep 8,086
Recall
Just had a recall on my 4 week-old F10. Recall 0064650100, some kind on water ingress seal on the A/C electrics.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
06-15-2011, 07:14 AM | #4 |
Rep 698
Details;
0064650100 - BMW (UK) Quality Enhancement Procedure - Delivery stoppage - Seal the fan housing - F0x F1x Situation Due to a manufacturing defect, the fan housing of the vehicles concerned is not leaktight. Effect Moisture can enter the vehicle interior through a hole in the housing cover. Vehicles concerned F0x F1x According to VIN selection (15.04.2011 - 21.04.2011). Action Seal the fan housing using butyl. Procedure Disconnect the battery negative lead, see Repair Instructions 61 20 900 "Disconnect battery negative lead". Remove the right/rear dome strut, see Repair Instructions 51 71 346 "Remove and refit/replace (rear) right dome strut". Undo the auxiliary electronics box and swing it to one side. Undo the screws (1) from the fan housing cover (2). (Similar to graphic). 1untitled.bmp Lift the housing cover slightly and turn it to one side. Seal the triangular hole in the upper right area (see graphic below). Butyl must be used as the sealant, similar to part number 83 19 2 165 900. You do not have to order this part number if you have other butyl available in the workshop. Note: A maximum amount of 2 cm of butyl is required for sealing. |
06-15-2011, 07:19 AM | #5 |
1400
Rep 8,086
Interesting. Mine was booked in on Monday but I had a call from the dealer saying "the part had not arrived from Germany" and that I'd have to rebook for the following week. If it just needs butyl sealant then what gives???
Ian
06-15-2011, 08:09 AM | #7 |
1400
Rep 8,086
I'm assuming it's an example of dealer bullshit. Where did you find that info, Mud, and do you have the pictures that go with it?
Ian
06-16-2011, 01:42 AM | #10 |
1400
Rep 8,086
Perhaps, but I can see no reason why you'd need to replace a gas strut on a four-week old car?!
Ian
06-16-2011, 07:32 AM | #12 |
1400
Rep 8,086
Only one week of production so I don't suppose there's that many. I'm waiting for the dealer to call me when the "part" arrives.
Ian
