my radio display (non i-drive) is failing
06-02-2011, 06:19 PM | #1 |
Rep 222
It's the little red screen, started out as a few dead pixels, now the majority of the screen is very dim, almost invisible during the day, with a few spots which appear to be at full brightness. What sucks is my car's not under warranty anymore due to too many miles.
Has anyone ever had this occur before? Is there some sort of connector on the back of the radio that may have come loose? I have no idea how to remove the radio to check it. Anyone have any ideas on what could be going on? Thanks, Simon |
06-02-2011, 09:34 PM | #2 |
Rep 176
Take a bright flash light and shine it on to the screen. See if anything is showing but just not being light up. If that is the case than the screens backlight is dying. In that case you just need a new screen. I don't know any numbers or how to do it but I'm sure plenty of people on here do.
I'm just taking a guess, try the flash light idea though. Good luck! |
06-02-2011, 10:02 PM | #3 |
255
Rep 7,089
Drives: '06 AW 330xi
You can't just buy a new display....at least not an oem display.
06-04-2011, 06:04 PM | #4 |
Rep 222
here are some pics, if it would help at all
in this pic it's fine: in this pic it's not doing as well, but still a lot better than other times: I'll have to try the flashlight trick, but since it's only in spots on the display it leads me to believe it's not the backlight. I'm hoping it's just a loose connection since it's intermittent. Thanks, Simon |
06-05-2011, 01:11 PM | #5 |
613
Rep 2,000
Drives: '13 128i, '23 iX M60
Mine is doing the same thing
I'll schedule an appt with service. Should definitely be covered by cpo. L
2023 BMW iX M60 BSM
2013 BMW 128i 6MT MGM/CR. M-sport/Premium/Cold, HK, Xenons, BMW SSK and PE. ED 7-12-2013 SOLD: '07 E90 6MT BSM/Terra, '18 F31 Sunset/Oyster, '21 Polestar 2 http://www.1addicts.com/forums/showthread.php?t=897862 |
06-05-2011, 08:48 PM | #7 | |
Rep 222
would it work with L7? How much? |
06-05-2011, 09:38 PM | #8 | |
255
Rep 7,089
You can most likely get the HU recoded for L7. |
06-06-2011, 08:35 AM | #9 |
Noob
18
Rep 288
I didnt have L7, had the middle-line system (forget the name), but check if you can get it coded and if so PM me and we can work something out!
06-06-2011, 08:52 AM | #10 |
these cars become an addiction :/
13
Rep 235
it doesnt?!? i did not know that good sir!
06-06-2011, 08:54 PM | #11 |
613
Rep 2,000
Yeah apparently the CPO doesn't cover the radio (or nav for that matter) either. What the f! BMW should not make products that start failing as soon as the warranty is up. I'm barely 6 months out warranty and 46,000 miles.
2023 BMW iX M60 BSM
06-10-2011, 01:51 AM | #12 |
80
Rep 586
What's the temp outside your car when it happens... I jave had it happen 2 in the past week and it as 95 degrees with 90% humidity. As the car cooled down the display when back to normal. Expect similar results in very cold weather too.
2021 Mercedes G550
2015 X5M 2020 Supra-JB4, DP 2008 M5 with muffler delete-sold 2007 650i-sold 2008 335i-JB4, DP, Meth-sold |
06-14-2011, 12:40 PM | #14 | |
Rep 51
hmmmm.... I havent noticed the correlation between the screen acting up and temps, but I also experience sound cutting out from the drivers side for like 20 seconds then it comes back. Anyone else getting this? |
06-14-2011, 06:12 PM | #15 |
Noob
18
Rep 288
I have sound cutting out intermittently during my commute. Im thinking its my battery being 6 years old..
06-14-2011, 08:01 PM | #16 |
Rep 51
I replaced my battery about 6 months ago so that cant be it for me. I think the HU is dying. Its frozen up on me a few times where it becomes completely unresponsive to any controls.
06-20-2011, 10:32 AM | #17 |
Rep 11
Same here. Just took it in to see if they would replace it under CPO warranty...nope. Said a replacement would cost $1325.53!
06-21-2011, 03:19 PM | #18 |
Rep 1,044
i just noticed the same thing since its been around 100degrees here the past few days. the top line looses some of the dots after the cars been siting in the sun. but in the morning or after its in the garage its back to normal. seems like a design defect that bmw should address.
06-21-2011, 04:18 PM | #19 |
255
Rep 7,089
Do you have bluetooth? There's a known issue where the radio will freeze up because the TCU freezes up.
07-05-2011, 06:03 PM | #20 |
Black.e90
16
Rep 147
Mine is doing the same thing. When it is cool out (like when I leave for work in the morning) the radio display is normal. But after the car has been sitting in the sun it all but disappears. Mine too is out of Mftr Warranty, but I still have extended, would the extended cover the radio display?
Here is my display: View post on imgur.com
Current: 03 M3 6MT Carbon Black/Cinnamon; 1963 Volkswagen Beetle Ragtop; 1965 Ford Mustang Conv. 289/4spd Retired: 2006 325i 6MT, 1966 Ford Mustang; 2006 VW Jetta 2.5L, 5MT |
07-05-2011, 08:40 PM | #21 |
Rep 17
Heat Wipes Out Display
Must be a common problem. '07 328i in Florida - many pixels missing on display until A/C cools down the car - then it looks like it should. Warranty long gone, so I just Bluetooth a smartphone into the system for sounds.
07-05-2011, 08:53 PM | #22 |
126
Rep 1,984
Drives: F15 35i
Another Florida guy here, same thing as said above. Almost invisible during a hot day, but garage start it is flawless...
See my full mod list in my garage
