Speaker Hiss with volume at 0 after amp install
05-29-2011, 10:37 PM | #1 |
Rep 145
I just got done installing JL Audio XD600/6 using Technic's harness. Also adjusted input sensitivity as per manual. System sounds great but when turned all the way down I hear a slight hissing sound from speakers.
Any thoughts? |
05-30-2011, 12:31 AM | #5 | |
289
Rep 3,201
I think your gain needs to go down. But this is HiFi, right? Where is your treble control? |
05-30-2011, 07:09 AM | #6 |
300
Rep 3,969
Turn the gain down on the channels connected to the mids and tweeters, until you no longer hear the hiss. You probably won't need all the amp's reserves for those speakers and maxing out the gains can introduce unwanted noise.
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
05-30-2011, 08:15 AM | #7 |
688
Rep 6,845
Drives: 2018 Audi RS5 coupe
An oscilloscope is not needed per manual
Just an AC voltmeter If you hear hiss when volume is at 0 Then you gain is set too high
05-30-2011, 07:15 PM | #8 |
Rep 145
Even with gain set to 0 there is still some noise. The noise is lower but still there. Could the rca cables be the cause?
Even with treble all the way down, there is still hiss. Last edited by digitaldav; 05-30-2011 at 08:32 PM.. |
05-30-2011, 07:27 PM | #9 |
688
Rep 6,845
Try unplugging the inputs to the amp, and check for hiss
05-30-2011, 07:33 PM | #10 |
289
Rep 3,201
05-30-2011, 08:47 PM | #13 |
2309
Rep 13,018
05-31-2011, 12:40 AM | #17 |
2309
Rep 13,018
05-31-2011, 11:34 AM | #19 |
255
Rep 2,547
Should unused inputs be 'plugged' with blank rca's ??? For example, the xd600 has 3 pairs of rca inputs, with the hifi harness we are using 2 pair, can noise come in from the unused 3rd pair?
05-31-2011, 12:12 PM | #20 | |
688
Rep 6,845
in that case the amp is faulty
05-31-2011, 02:11 PM | #21 |
2309
Rep 13,018
The unused 3rd pair in the XD600/6 is internally connected to CH1-> Ch4 when the input switch is set to 4-input.
05-31-2011, 03:24 PM | #22 | ||
289
Rep 3,201
I will quote a paper by Davind Navone and Richard Clarke of Autosound 2000 on troubleshooting noise. (I will fall back on citing an "authority"...) Quote:
We all live and learn. |
