E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - California > e92 Driverside window hitting the trim *Need Help*
Reply
      04-21-2011, 05:18 PM   #1
taioneren
Drives: blue e92 335i
Hi, I recently got a used 08 e92 335i and according to the first owner, the driverside window was damaged and replaced with OEM windows. I don't know if it is not install properly or what, but when I close the door the window somehow get on top of the trim. I tried the passenger side and it works wonder, you close the door, the windows move up just a notch to close the gap. It getting really annoying that I have to push the windows down before closing the door so it don't damage the trim or the windows. Does anyway have this kind of problem before? and how was it fixed? I really need some help as it is becoming a hassle. I want to shadowline the trim, but knowing that if i forgot to push the windows down when I close the door, it might damage the trim. Any help or input will be greatly appreciated. Thanks
      04-22-2011, 05:21 AM   #2
DetailAddict
Drives: 2008 BMW 328i
are u just out of warranty? was the work done under insurance? do u have the paperwork on the repair?
      04-22-2011, 01:44 PM   #3
supahdave
Drives: 09 AW 335i Sedan
Window regulator needs to be replaced.
      04-22-2011, 01:45 PM   #4
Hey Ant
Hey Ant's Avatar
Drives: E90 M3
Try the window resetting procedure:
1. Hold down on the window switch until it fully opens, continue holding the switch for 10 seconds. Then release.
2. Pull up on the window switch until it fully closes, continue holding the switch for 10 seconds. Then release.
3. Repeat steps 1 & 2 until you hear a "clunk" sound. Your window have been successfully reset.
Good luck.
      04-22-2011, 04:15 PM   #5
taioneren
No, I still have the original warrenty until Feb 2011, I don't know if the work was done under insurance and no, I do not have the paperwork on the repair.
I will try the reseting procedure, if it doesn't work, i will bring it in and have the regulator replaced. what exactly is a "clunk" sound? just wondering
Thanks all for the reply
      04-22-2011, 04:40 PM   #6
Hey Ant
Hey Ant's Avatar
Drives: E90 M3
that clunk noise just means your window has been re-initalized from the anti-trap feature. Anti-trap only occurs when the battery terminals have been disconnected for a while.
Your window regulator is not broken.. Symptoms of a bad regulator would conclude to your window not being able to roll up or down.
      04-22-2011, 05:13 PM   #7
colorblue
Drives: 04/07 328i convertible
great tip! I sometime encounter this problem:
On driver side window, I tried to roll all my windows up at the same time with all up key, but the driver side window rolls back down in the middle of the process...
do you think reset will fix it too?
      04-22-2011, 05:35 PM   #8
Hey Ant
Hey Ant's Avatar
Drives: E90 M3
yes it will.
      04-22-2011, 06:32 PM   #9
colorblue
Thanks, will try!
      12-03-2011, 01:36 PM   #10
noipip
E90 325I / E92 335I
noipip's Avatar
Drives: E92 335I
Window Reset Procedure
Good luck.
I tried to follow this procedure and its work great. Since i disconnected my battery to install JB4. After reconnected the battery. The driver side window didn't automactic roll up and down when i close the door and also it is hitting the trim too. Thank You so much~ Its a great help~
Areo Lip, 6000k Hid Angel Eye, 6000K Hid Fod, AFE Stage 2 Intake, Greddy Bov, JB4 PnP, 19" BBS LM Rep gold, Hankook Ventus V12, H&R Racing Spring, Silver CF Trim, CSL Trunk.
      12-04-2011, 04:56 PM   #11
Hey Ant
Hey Ant's Avatar
Drives: E90 M3
You're welcome!
      06-17-2019, 02:37 PM   #12
Insomniaroy
Drives: 2010 E92 M3 DCT
Does NOT work ('09 E92 M3) , Like 90% of things written on these forums..
Tried it with all combinations.
The only way is to disconnect the battery , or use ISTA / INPA.
      01-19-2022, 02:01 PM   #13
tjtiger83
Drives: 2011 335i xdrive
@Hey Ant, thanks for the tip, it definitely helped me out.
      01-24-2022, 06:23 PM   #14
Hey Ant
Hey Ant's Avatar
Drives: E90 M3
Youre welcome!
This is such an old post from way back! You're welcome!
Reply
e90post
