E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > fs:K+DCAN Cable for Coding
Reply
      04-05-2011, 05:29 PM   #1
lionheart90k
Indonesia
59
Drives: '09 e92 M3
One K+DCAN Cable for Coding...
lmk whether you have the 09+ model car or Pre-09... if it's pre-09 i would solder the pin 7-8 for you if not i'll disconnect the soldering between pin 7-8
asking price : $85 Shipped
Andre
      04-05-2011, 05:43 PM   #2
fdriller9
Drives: '06 AW 330xi
2006 330xi  [6.44]
Interested but why do you need to solder anything?
I thought 06s just needed Kcan and post 06 needs Dcan.
      04-05-2011, 05:53 PM   #3
Dracon
Drives: 2013 F10 M5
2013 BMW M5  [0.00]
It depends on the application and vehicles you are using it in, some older chassis cars have two K-Lines, one on pin 7 and one on pin 8 so most cables have pins 7-8 connected/soldered to accomodate that.
07-09 D-CAN cars don't use pin 8 but still does use pin 7 so the cable continues to work fine, but in 09-10 BMW re-used the pin 8 position for ethernet, so if you have an interface that has pin 7-8 connected (and most of the ones you find on eBay and such do), you'll get errors trying to communicate with the car because of the ethernet connection at pin 8 interfering with the D-CAN connection on pin 7.
This is one reason I'm planning to get a J2435-1 compliant cable and try it out (to be used in the times I don't want to break out the big orange OPS head). EDIABAS supports J2435-1 passthru and a compliant cable, like a Tactrix OpenPort 2.0 cable should work on any model without modification.
And it should work with ISTA online at www.bmwtechinfo.com for diagnostics and programming.
      04-05-2011, 07:03 PM   #4
CasperSYTFU
SYTFU Crew
CasperSYTFU's Avatar
36
Drives: 2010 Toyota FJ
PM'ed you
      04-06-2011, 12:40 PM   #5
fdriller9
2006 330xi  [6.44]
Good to know. Thanks!
      04-06-2011, 04:38 PM   #6
lionheart90k
Indonesia
59
Drives: '09 e92 M3
SOLD
      04-06-2011, 04:57 PM   #7
shag
pullin a boat
shag's Avatar
37
Drives: 2021 X3 M40i
DOH! I just bought a USB cable on eBay, from a seller in Ontario. You're telling me that there's a good chance it might not work with my 09?
2021 X3 M40i, Phytonic/Cognac
Past:
2017 330i xDrive Touring M Sport, EBII, Dinan
2014 328d xDrive Touring M Sport, BSM/CR.
      04-06-2011, 06:41 PM   #8
lionheart90k
Indonesia
59
Drives: '09 e92 M3
just take out the solder between pin 7 and 8..... just check it when you get it... that's all
Andre
      04-06-2011, 07:38 PM   #9
Dracon
Drives: 2013 F10 M5
2013 BMW M5  [0.00]
No. It should work just fine. You might just need to desolder pins 7 and 8.
Most eBay sellers are starting to catch on and start offering cables with the pins disconnected and supply an adapter for older cars to link pins 7 and 8.
See one of my earlier threads for a list of chassis requiring the adapter.
Reply
e90post
