E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > I just had my oil changed...
Reply
      02-23-2011, 10:55 PM   #1
Blubaron79
Blubaron79's Avatar
Drives: 2021 M340i xDrive
And it's down one notch when check it after driving it home. Is this something I should worry about?
I'm afraid if I go back and they top it off, they will over fill it. Isn't a little less oil better than too much oil??
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive
      02-23-2011, 10:58 PM   #2
Chriztofor
Chriztofor's Avatar
Drives: '06 325i and '13 X5
Yep it can be flaky at times, check again tomorrow. BRING BACK THE DIP STICK.
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
      02-23-2011, 11:12 PM   #3
Blubaron79
Blubaron79's Avatar
I knew this might start the dip stick debate...
      02-23-2011, 11:13 PM   #4
Chriztofor
Chriztofor's Avatar
      02-24-2011, 03:38 AM   #5
x26
x26's Avatar
17
Drives: 335i
Go Dipstick Go!!!
      02-24-2011, 05:02 AM   #6
Spydeputy
Spydeputy's Avatar
Germany
205
Drives: 2015 F23 M235i/2008,E90,335xi
There is no debate, everyone but BMW wants it.
      02-24-2011, 05:26 AM   #7
Chriztofor
Chriztofor's Avatar
Actually there is one person that thinks that the e-dipstick is just fine. I respectfully disagree.
http://www.e90post.com/forums/showth...light=dipstick
      02-24-2011, 07:33 AM   #8
ceb
NHTSA Nazi
28
Drives: 335ix
We have to remember that 99.9999% of the population never checks the dipstick and 99% couldn't find it on a car with a dipstick.
Checking oil levels was less important in the days of 3k oil changes but it becomes vital with 15k intervals.
Remember that the "full" is really immaterial. What is important is knowing when you are reaching critically low levels and the "e-dipstick" is intended to do that.
      02-24-2011, 07:36 AM   #9
335BBS
55
Drives: 2009 335 coupe.
I didnt even know my car didnt have a dipstick. I feel like a bit of a dipstick.
      02-24-2011, 08:36 AM   #10
Verbiage
Dismembered Member
Verbiage's Avatar
Jamaica
3610
Drives: F80 ZCP 6MT, R55 Clubman S 6MT
InB4 derailed thread and [more] dipstick jokes.
My delivery experience and beach photoshoot here.
      02-24-2011, 08:41 AM   #11
Chriztofor
Chriztofor's Avatar
I agree, most people don't check their oil, but a low level light would have sufficed. If it worked pefectly I would love it too, but it does not read the correct level of oil all the time and that makes me feel uneasy. As the cars get older more people will complain about this.
I would also like to know, not the hard way, if the senor fails altogether will it tell us so on the dash?
      02-24-2011, 08:46 AM   #12
335BBS
55
Good point. Is there backup? Had a sensor fail on a Yamaha outboard and fried the engine.
      02-24-2011, 09:08 AM   #13
Blubaron79
Blubaron79's Avatar
My question was: If it's one notch low; is that ok?
      02-24-2011, 09:12 AM   #14
redline2001
Drives: AW 328i
There is a low level indicator. It comes on when you are down a quart.
      02-24-2011, 09:13 AM   #15
creepy coupe
creepy coupe's Avatar
1868
Drives: BMW M340I G20
2015 BMW 435d  [0.00]
2009 335i  [0.00]
It's ok BB, I just had mine changed and was in the workshop under the car with the Tech. I watched him put 8.4 litres back in my engine and it still read one notch low.
He said it would be fine and anymore might overfill it, which was a lot harder to rectify.
I'd say you'll be fine
      02-24-2011, 09:15 AM   #16
968tomr
Drives: 2007 E92 335i
Blubaron
Yes - if you are down one notch it indicates you are within tolerance. When I had a dipstick and changed my oil I would always shoot for somewhere between half full to topped off. If you add more you could easily overfill - so I would wait until you get down to 3/4 low and add half a quart (as the indicators typically show you 1 Litre from the bottom of the graphic to the top).
-Tom
      02-24-2011, 09:16 AM   #17
m42stanle
N52B25
15
Drives: 2011 E90 LCI (323i)
Yes probably.
But if you're as paranoid as me why not pick up a quart from the dealer and then add it yourself 1/4 bottle at a time until the e-dipstick shows full again? $7-8 seems a pretty small price to pay if this is going to keep you up at night.
      02-24-2011, 09:16 AM   #18
BMWsky
Drives: 335i
I can't imagine having it one notch low would cause any harm at all. Even if the car were a quart low, you'd be fine as long as oil levels didn't continue to fall. That's what I'd watch more carefully.
      02-24-2011, 09:23 AM   #19
Blubaron79
Blubaron79's Avatar
Cool. Thanks!
      02-24-2011, 09:29 AM   #20
335BBS
55
Why would you ask here? If you get the wrong answer, then what? Try the owners manual.
      02-24-2011, 09:39 AM   #21
Verbiage
Dismembered Member
Verbiage's Avatar
Jamaica
3610
In iDrive? Yeah man. As long as the bars are green. It should say "Engine Oil Level O.K." or something.
      02-24-2011, 10:13 AM   #22
Lenaxia
Drives: 2006 330xi 6MT
2006 330xi  [0.00]
Out of curiosity, what are the consequences of overfilling the oil? Obviously never tried it myself so dunno what it would do.
Reply
e90post
