Speaker Question
01-23-2011, 11:01 AM | #1 |
Rep 58
Speaker Question
Has anyone have a link to a DIY thread showing someone increasing the size of the front and or rear speakers?
Or any tips on doing this? Thanks
[SIGPIC]
01-23-2011, 11:47 AM | #2 | |
2309
Rep 13,014
01-23-2011, 03:47 PM | #3 |
Rep 58
Thanks technic, what knowledge have you got on Harman Kardon products? I have come across this amp, which to me seems to have a good spec, but not knowing much about audio i just wanted to get someone with experience to take a look at it.
CA470E - 4 channel amplifier £249.99 Multilayer boards with high-quality SMT parts and shielded transformers ensure minimum noise and distortion. High-current capability with high output power into low impedances guarantees perfect control of critical loads such as those from power-hungry subwoofers. Aluminum heatsink with casted end caps and brushed-silver aluminum inlays combines maximum heat dissipation with elegant design. Single-screw RCA connectors and heavy-duty power and speaker terminals for long-lasting connectivity. Acrylic top cover with brushed-aluminum Harman Kardon® logo; badge features blue ambient light. New RJ45 multichannel audio and control inputs and outputs for easy single-wire system connections. Variable electronic crossover networks and subsonic filters on all models. 4-channel amplifier Power Output (4 Ohms): 85W RMS x 4 Power Output (2 Ohms): 135W RMS x 4 Power Output (2 Channel): 270W RMS x 2 Crossovers: Front: Low Pass/High Pass/Off - 12dB/Oct Rear: Low Pass/High Pass/Off - 12dB/Oct Signal-to-Noise (dBA) 104dBA (reference rated power into 4 ohms) THD 0.05% (rated power at 4 ohms) 3 x 20Amp Fuse Rating Frequency Response 10Hz - 100kHz Dimensions (L x W x H) 234mm x 404mm x 62mm
[SIGPIC]
