Could a dying battery be bad for the electronics?
01-05-2011, 06:21 AM | #1 |
Rep 804
My 2006 E90 with 49k miles is still running on the same battery from day 1 (manufacteured sometime in 2005). Within the last year I've had the front door lock busted (probable actuator failure, fixing it this week) and my adaptive headlights stuck pointing right one night (but fixed the next morning when i started the car up).
I'll be getting a new battery (and registering it) in a few weeks but Im just curious. |
01-05-2011, 11:49 AM | #2 |
133
Rep 4,764
Yes - I played around with a light weight battery in my car and after a year the thing started to be marginal at best:
1) Comfort Access would not work 2) Radio Volume would just shut off at random times 3) ABS warning lights would come on 4) Sunroof would sometimes open, sometimes get an error when you tried to open, and sometimes get stuck open. The error for the sunroof showed voltage issues. Put the stock battery back in and all electronic issues are gone. |
01-05-2011, 01:21 PM | #3 | |
255
Rep 7,089
Drives: '06 AW 330xi
OP, our cars will put some modules into a power save type mode and prevent further battery discharge. 1) To prevent you from being stranded. 2) To prevent damage to the battery from low voltage. Door actuator problem is a known problem and isn't related to the battery as far as I know. Not sure of the headlight problem though. |
01-05-2011, 05:27 PM | #4 |
133
Rep 4,764
Yes I did. I registered after the lightweight battery was put in, and I registered again when I took it out and put the OEM battery back in.
01-05-2011, 05:41 PM | #5 | |
255
Rep 7,089
I'm going to be putting in a Braille 21lb lightweight battery tomorrow but the only thing that concerns me is the CCAs since I'm Jersey. I'll probably end up using a battery heater/tender combo |
01-05-2011, 06:09 PM | #6 | |
133
Rep 4,764
I have a battery tender and would hook it up if I went more than about 5 days without driving the car. I have 17,500 miles on the car in 3 years and 8 months. |
01-05-2011, 07:12 PM | #7 | |
255
Rep 7,089
Our cars don't charge the battery until the engine is properly warmed up. So short distance driving doesn't charge the battery. |
01-06-2011, 09:35 PM | #8 |
Rep 1
Changing your battery
If you plan to do it yourself this post is very helpful in changing your battery - it's in the DIY Guides portion of this forum:
http://www.e90post.com/forums/showth...hlight=battery Posted by GeneralXception on 08-14-2009 |
