E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - Hawaii > FS:BBS Lug Nuts | Studs
Reply
      11-18-2010, 08:10 PM   #1
Evan_RS
Evan_RS's Avatar
Drives: M
keeping it, too many flakers.
      11-18-2010, 10:26 PM   #2
Novator
Novator's Avatar
Drives: '04 E46 M3
2004 BMW M3  [8.00]
Will this work with an E82? These are pretty neat. If so, consider me very interested and a potential buyer.
      11-19-2010, 02:38 PM   #3
Evan_RS
Evan_RS's Avatar
Drives: M
Yes, it will work.
      11-19-2010, 07:15 PM   #4
Novator
Novator's Avatar
Drives: '04 E46 M3
2004 BMW M3  [8.00]
You coming to Toys For Tots, might by them off from you then if you bring them. I can't help but get all excited over some lug studs, lol. Definitely beats OEM hands down. Who did you buy them from? WheelSTO?
      11-19-2010, 07:17 PM   #5
Novator
Novator's Avatar
Drives: '04 E46 M3
2004 BMW M3  [8.00]
PS-Are they new (fresh out of the box) or have they been used? What torque do you use to apply them, is Loctite required? What type of tools (i.e. sockets) are needed to fit these?
      11-19-2010, 08:21 PM   #6
Evan_RS
Evan_RS's Avatar
Drives: M
Yes, everything is brand new.
I'm don't know how many LB to torque the studs, but I will find out for you.
Tools:
Allen socket for the studs, not sure about the size.
I think 17mm sockets for the BBS Lug key.
A torque wrench.
      11-19-2010, 08:23 PM   #7
Express
Express's Avatar
Israel
369
Drives: 06 330i
2006 BMW 330i  [8.30]
you need a hex bit. my studs were 7/16 hex bit i think.. i don't remember.
you need to use red loctite, and its not by ft lbs, you have to visually check the back of the hub and make sure the stud is flush with it. you can't torque a stud in an open hole. its just not possible.
      11-19-2010, 10:12 PM   #8
Novator
Novator's Avatar
Drives: '04 E46 M3
2004 BMW M3  [8.00]
Would switching to lug studs from bolts be more of a hastle than it would be a blessing? Can anyone give me the pros and cons of both setups? Not sure if I will want to buy these if they are only going to cause me headache. I do really want these, but I'd like to be more knowledgeable with my decision.
      11-20-2010, 04:21 AM   #9
MediaHI
MediaHI's Avatar
20
Drives: everyday
Studs pros-
-lighter than bolts depending on your studs and nuts
-if for some reason your bolts are lose, your rim would come right off (if you have studs, it will still come off, but might give you enough time to notice)
-fast rim change
-nicer since there's more nut choices
cons-
-it's not a snap on process, you will have to loctite it
the studs should be torqued to 15-20lbs if I remembered correctly and nuts should be 80-90lbs. Those are the specs I followed, might be different for you but idk. I've never had a problem with studs.
Ricky also did a stud conversion, PM him to see if he could help you set it to the proper torque spec.
      11-26-2010, 11:19 AM   #10
Novator
Novator's Avatar
Drives: '04 E46 M3
2004 BMW M3  [8.00]
After talking to the distributor of the wheels I am getting I won't be able to buy these lugs/studs/nuts from you. If I were staying stock these would be a very attractive option, but since I plan on fitting wider rubber in the future the lugs will be too short and I won't be able to fit any spacers when/if needed. Bump for a great product that is quite rare. Anyone who plans on staying stock or running no spacers should consider this kit.
      11-26-2010, 11:31 AM   #11
Evan_RS
Evan_RS's Avatar
Drives: M
Lugs is not a problem, you just need longer studs if you are getting spacers.
My wheels are F: 20x9 offset +8 R: 20x10 offset +18 and these studs and lugs will fit without a problem.
      11-27-2010, 12:59 AM   #12
Novator
Novator's Avatar
Drives: '04 E46 M3
2004 BMW M3  [8.00]
Lol, that's what I meant, I will need longer studs.
      12-10-2010, 02:36 PM   #13
Evan_RS
Evan_RS's Avatar
Drives: M
bump
      12-29-2010, 08:04 PM   #14
808E90
808E90
808E90's Avatar
Drives: E90 ///M
... no one called me
LTMW FTL . Karbonwerks LCI Trunk . Vorsteiner Poly Front Lip . NA Motorsports LUX H8 . RECARO Pole Position Seats . BMW Performance Pedals . BMW Performance Performance Grills . BMW Painted Fender Grills . BBS 19x9.5 19x11 LMs . Michelin PS2 265/295 . H&R Sport Springs . Wheel Mate 45/55MM Stud Kit . BBS Red Lug Nuts . ESS VT1 Supercharger . Akrapovic GT4 Exhaust
      08-23-2011, 11:42 AM   #15
HIJB335i
HIJB335i's Avatar
Drives: 335i
Lugs and studs still for sale?
      08-26-2011, 02:42 AM   #16
Evan_RS
Evan_RS's Avatar
Drives: M
sorry, these were long gone.
Reply
e90post
