Advice on battery replacement for E90
10-26-2010, 08:15 AM | #1 |
1321
Rep 6,319
I'll post this here but if it's a wrong forum may be the mods could move it.
I need help with picking out battery replacement for my car. Any advice? Has anyone else here had to replace battery not from dealer on a car older than 4 years old? I'm not sure which brand to go with, thinking between Varta and Bosch? Any other suggestions?
F30.F11.E86.E90.E90.E36 |
10-26-2010, 08:32 AM | #2 | |
I ask the questions you're afraid to ask.
44
Rep 2,489
Search the E90 forum for the battery thread. Here it is. Post #6 has the link to to the original thread. http://www.e90post.com/forums/showthread.php?t=445615 Last edited by cb1111; 10-26-2010 at 08:36 AM.. Reason: added link |
10-26-2010, 09:47 AM | #3 | |
300
Rep 3,969
Here in the States, you can go to Walmart and get a replacement battery (with higher CCAs than stock) for around $75. Installation takes about 30 minutes. I did this on two cars so far without any issues whatsoever. Compare that with going to the dealer and spending $300 - $400, for a battery that is not proven to last any longer than the one from Wallymart, then make your choice. |
10-26-2010, 11:23 AM | #4 |
2309
Rep 13,018
Battery registration is very dependent on what options are in the car and how much current draw is in the system.
I'm having too many "low battery charge" messages after replacing my OEM battery with a brand new Die Hard with the same specs. So the battery registration has to be done in my M3 while too many forum members here don't have to even with Walmart batteries. |
10-26-2010, 12:14 PM | #5 | |
300
Rep 3,969
10-26-2010, 01:32 PM | #6 |
Rep 219
Batteries do all the same give power to your car. The problem with the battery is the car. If the battery is bad our car will start saving power by not give full air blast from your A/C for example (that happened to me) and if you use some other stuff that uses a lot of power the computer will do the same. So if you don't regist your battery your car will be running fine but some times will act weird because the computer still thinks that you still have a weak battery. So it's up to you. (BMW's are a hand full my friend)
10-26-2010, 02:03 PM | #7 |
1321
Rep 6,319
Im having pretty rough cold starts on my diesel lately so I'm guesing tomorrow Ill check how the batter reading looks like then act accordingly. Dealer wants 250usd for battery and I've no clue about the installation and if that's going to cost me anything near 100 bucks you guys talking about.
I drive little also and may be that's the reason it's discharging quickly. Battery I heard will lose about 12% of its power in a week if car is not driven - hence it's important to have mine replaced - i just wants clear if better to go with OEM one or with something like from Bosch or Varta. PS_ thanks for the links on the issue CB1111!
10-26-2010, 04:48 PM | #8 | |
44
Rep 2,489
What we do know is that the BMW shop manual requires registration. If you want to cheap out and take your chances then it is your car and just another reason why I'll never buy a used BMW. You guys spend money on crap mods and cheap out on proper maintenance - go figure. |
10-26-2010, 05:02 PM | #9 | |
300
Rep 3,969
Look, I responded to your recommendation since I wanted the OP to be aware that there is a less expensive option, and for him to be able to make his own decision. You are obviously happy for spending $400 on a $100 battery, and I am happy for spending $75 on a $400 battery. So we are both happy. |
10-26-2010, 09:36 PM | #10 | |
44
Rep 2,489
Just out of curiosity - did you read the two other threads? |
10-27-2010, 01:17 AM | #12 |
1321
Rep 6,319
i have to say in US they seem to charge way too much for battery at the dealership. here it's one thing that's unusually cheaper. normally things are more expensive in europe.
10-27-2010, 08:32 AM | #13 | |
300
Rep 3,969
This is the first time I've heard about potential issues with non-registered batteries. I guess the jury is still out though. |
10-27-2010, 12:24 PM | #14 | |
300
Rep 3,969
10-27-2010, 02:51 PM | #15 |
Rep 1,428
i have had two modern used bmw's and have had to replace batteries in both. first time i went to autozone like any normal person would, the battery i received looked the same but that was the only thing in common. i couldnt leave the car sit for more then one day or it wouldnt start. i ended up at the dealer and bought an oem battery and installed it myself. that was a 2000 528, now with my e90 i had to have the dealer install it because of that crazy contraption on the top of the battery not only the registering process. now you can take my advise or not but if you buy an aftermarket battery you very well may find yourself at the dealer anyway so why even bother. if you wanted to save money on maintenance there are plenty of auto makers out there with much lower predicted maintenance costs.
10-27-2010, 04:16 PM | #16 |
486
Rep 1,614
Somewhat off topic: in the case of those who have cars that sit for days at a time is it common practice to use some sort of battery tender to keep the battery fully charged <and thus avoid the issue of a discharged battery>?
10-27-2010, 07:29 PM | #17 |
Rep 1,428
you are correct but i am talking about the fact that if i didnt happen to go anywhere one day the next the battery would be dead. after i got an oem battery i didnt have that problem.
10-27-2010, 08:02 PM | #18 |
Rep 15
Battery Replacement
replaced my battery last weekend with Everstart Maxx at WalMart; $77 +tax. I got a warning light last winter and the air cond blower was turning off intermittantly, radio would shut itself off after less than a minute after car shut off, then I got low batt warning. I was hesitant at first, but once I got into it it wasn't too bad. Getting the Maxx series 49 battery was a hook-slide into the compartment but once in was an easy connection. (FYI I bought the bentley manual on amazon for 88 bucks, well worth it). Everything started up fine, no weird warning lights or anything.
Why I didn't go to the dealer ? They quoted me between $430 - $530 + tax, depending on the battery I had. When I asked what registration cost (alone) they said 2 1/2 hours, same as full replacement. (+ they would've charged me $3.98 to top off my washer fluid, something they'd done at least once). Suffice it to say that dealer won't be getting my business any longer. I haven't registered yet but still plan on it but so far nothing abnormal. I figured if I french-fried the electrics i'd have to junk the 325 and upgrade to the twin turbo |
10-27-2010, 09:45 PM | #19 | |
44
Rep 2,489
There is plenty of information in these (now three) threads for people to make up their own minds. |
10-27-2010, 10:27 PM | #20 | |
300
Rep 3,969
Like I said, the jury is still out. |
10-27-2010, 11:09 PM | #21 |
Rep 1,428
do us all a favor save yourself a hundred bucks and learn for yourself then you can come back and say half of us were wrong, which ever half it turns out to be.
10-28-2010, 05:03 AM | #22 |
300
Rep 3,969
