E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > 328 Differential on a 335
Reply
      01-05-2007, 09:57 AM   #1
BayernMuenchen
BayernMuenchen's Avatar
13
Drives: 2007 335i Coupe
How about using a 328i differential on a 335i? The ratio on the 328i is different than the 335 and would allow for shorter gears and better acceleration.
328:
Final drive ratio 3.23 [3.73] :1
335:
Final drive ratio 3.08 [3.46] :1
2007 335i Coupe
      01-05-2007, 11:33 AM   #2
jonmacs22
Drives: 4-doors
I believe that the 335i diff housing is larger. do not change.
if you want to do any work on the diff, first install an LSD, and while you are doing that swap out the gearing.
a vendor like www.diffsonline.com can easily accomodate this request.
      01-05-2007, 03:43 PM   #3
Ghunger
Ghunger's Avatar
Drives: 330i
Might be worth waiting for the M3 to come out also. Might be an easy swap to put an M3 LSD in a 335 though the like the previous poster said, you may have to change the gearing a bit.
330i Monaco Blue, Terra /w aluminum trim, SP, PP, CA, PDC, Nav, Folding Seats, Sat Prep
European Delivery Blog
Picture Gallery
      01-05-2007, 06:22 PM   #4
ksfrogman
ksfrogman's Avatar
Drives: E90 330i 6MT
2006 330i  [0.00]
2006 330i  [0.00]
328:
335:
Your signature says you have a sports shifter. What does that mean? Steptronic? The steptronic and 6MT vehicles use different gear ratios.
      01-06-2007, 08:10 AM   #5
RichP
RichP's Avatar
Drives: F80
Pointless. The 335 has so much torque and power, it hardly gets traction in the first 2 gears as it is. The diff would make this even more pronounced.
      01-06-2007, 04:27 PM   #6
jonmacs22
Drives: 4-doors
Part of the reason for this is the open diff factor. if the cars had LSD's, even the standard 25% bmw usually does, it would make a huge difference. it would also enable customers to quickly alter their set-up to a 30-35% lock-up if they were into hard lower gear launches or tracking the cars.
Reply
e90post
