E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > E90 BC Menu Unlock
Reply
      09-07-2005, 02:47 AM   #1
Josh325
Josh325's Avatar
9
Drives: 325Lux auto idrive
E90 BC Menu Unlock
I would start by saying that it is the best forum than I read. I wish this forum will continue still a long time.
Well, I've got 2 questions for you:
1) I read a trick on the MT web site to unlock the BMW menu.
I would like to know if some had tested it ? and if yes, what arrived ? and how to relock the menu.
here is what I read:
For 'navigation' in the menu's, use the 'mileage reset button'.
To get IN the menu's push that button for approx. 15 sec.
Keep it pressed until you get the "01.__" in the display between the RPM and speedo-meter.
"XX.YY" means the menu-numbers.
If you want increase the "XX" part, push the 'mileage reset' button for approx. 2 sec.
As soon as you see "XX.__", you can increase XX by pressing the 'mileage reset' button.
Every 'push' increases "XX". If you want to increase the "YY", when the display shows,
for exmaple "01.00", then every 'push' on the 'mileage reset', will increase the "YY" value.
01.00 FGSTNR = "Fahrgestellnummer" (Chassisnumber)
01.01 K-ZAHL W/T
01.02 BMWTNR
01.03 COD DIA
01.04 KI HSTL DATUM = "Herstellungs Datum" (Manufactored/Essembled on date...)
01.05 ???
01.06 SW
01.07 KODIERDATEN
01.08 CAN
02.00 KI TEST = Dashbord test. All light, gauges, displays and so on will light up,
move.... works only when the engine is NOT running.
03.00 ??? (maybe it will show something after your first 'service', motoroil change)
04.00 MOM VBR = actual fuel consumption
04.01 RW-VBR-MOM = fuel consumption per hour
05.yy average fuel consumption
06.00 how much you have in your 'tank' in liters. Left- and Right compartment and Total
06.01 dito in hex?
07.00 KTMP-MOM = Temp. Cooling Fluid (celcius)
07.01 ATMP-MOM = "Aussentemperatur" Temp. Outside (celcius)
07.02 dito in hex?
07.03 N-MOT-MOM = RPM
07.04 N-VWF-MOM = max. RPM at the moment. E60 it gives a vlaue. E90 it shows "-----"
08.00 V-EFF = exact speed
08.01 V-ANZ = "Anzeige" speed shown on dash..
08.02 V-SZ
08.03 D-GESCHW 1 WEG
08.04 D-GESCHW 1 ZEIT
08.05 D-GESCHW 2 WEG
08.06 D-GESCHW 1 ZEIT
09.00 Voltage
10.00 KM/WOCHE
11.00 ??? , has to do how the time will be displayed
11.01 km or miles
11.02 Celcius or Fahrenheit
11.03 how to display fuel consumption. km/l or l/100km or mpg
12.00 V-ANKUNFT = arrival time 12.01 ANK-ZEIT = time of arrival
13.00 AUDIO = all(?) sounds. Like the 'boing' of the 'light on warning'
14.00 FS EINTRAEGE = error messages (if any)
15.00 Oil temp??
16.00 Dashbord lighting.
17.00 Temp inside in the car??
18.00 CC-TEST = you can see some of the 'check control' messages.
Look also at the iDrive screen!
19.00 UNLOCK
20.YY to 23.YY ???
That UNLOCK stuff is also important.
If not UNLOCKed, you can only see menu's 01 and 02.
In the '19' menu you must 'click-in' a unlock code.
That code you can calculate from the "FGSTNR" number.
You must add the last 5 figures of that FGSTNR number. for example:
: XXXXXX12345 the unlock code will be: 1+2+3+4+5=15
20.YY to 23.YY There is more to discover......
2) I have the iDrive with 8"8 screen but not the TV option. I would like to know if it is possible now to add the TV option easily (of course it would have been better to choose it at the beginning )
Thank you by advance for your answers
      09-08-2005, 10:13 AM   #2
Josh325
Josh325's Avatar
9
no idea?
325i sedan - black sapphire mettalic - iDrive Nav DVD - StepTronic automatic - PDC ...
      10-27-2008, 03:53 AM   #3
zoltan_tms
zoltan_tms's Avatar
Romania
Drives: BMW e90 330d,2006
2006 330d  [0.00]
Wink
1. I tried this procedure and everything was ok,you can do it too ,i say with no risks.
2.I also have the nav. pro. without the tv module,i know that it can be installed but dont know the price,I'd like to install it too.
Reply
e90post
