Does a 'base' 2007 328i come with an Aux' input?
06-08-2010, 09:43 PM | #1 |
Rep 5
Hello, all.
I'm in the market for a 328i, and I am considering a 2007 model. Does the base model 328i come with an auxilliary input (3.5mm) plug? |
06-09-2010, 08:15 AM | #3 |
Rep 221
06-09-2010, 08:48 AM | #4 |
Rep 194
You can also add iPod/USB integration as a retrofit, but then the connector is in the glovebox. From the factory, the USB port is in the armrest.
06-09-2010, 08:53 AM | #5 |
2309
Rep 13,018
06-08-2013, 12:17 PM | #7 |
Rep 2
I recently got a 2007 328i and I've found that the radio does have an AUX input option available. However, there is no AUX port in the armrest area (where the port is typically located, there is an open rectangular cut out). Is it located somewhere else that I'm not aware of?
Thanks in advance! |
06-08-2013, 08:39 PM | #8 | |
@McAuley7
11
Rep 419
06-09-2013, 10:38 AM | #9 |
Rep 2
06-09-2013, 10:06 PM | #11 | ||
@McAuley7
11
Rep 419
[QUOTE=kyleabaker]
So it's a hole, try to do something like this to find wire if u can't ill take mine out and see http://www.m3post.com/forums/showthread.php?t=740729 |
06-09-2013, 10:25 PM | #12 |
@McAuley7
11
Rep 419
Took a quick look, looks like this but also read its just a normal one u can get anywhere that true? Idk probably not ill look at mine tomorrow
http://www.getbmwparts.com/partlocator/index.cfm?action=MorePartInfo&PartID=786023&siteid =214672&catalogid=4462 |
