How do you say "Camber", "Toe" and "Castor Angle" in Chinese?
05-27-2010, 09:39 PM | #1 |
Rep 234
I am bringing my car to a mechanic for a check-up of wheel alignment. I often have difficulties explaining to the locals since my Chinese is not good enough and their English isn't the best. So how do you say and pronounce "Camber", "Toe" and "Caster Angle" as well as the steering wheel and it's control rods in Chinese? Many thanks.
05-27-2010, 10:14 PM | #3 |
newborn bimmer patriot
47
Rep 280
Diagrams are more effective than words
2008 E92 335i
JB/SB/Alum | Sports | M3 Tri-Stiched Steering Wheel w/ paddles | Full M-tech bodykit | Vorsteiner Bootlid | 19" LC Z2S | and more's coming... |
05-30-2010, 07:36 PM | #5 |
Rep 234
Thanks so much oda and pvhui, can you tell me how to pronounce those terms? Thanks again!
P.S-How do you say "understeer" and "oversteer" in Chinese too? |
06-07-2010, 12:16 AM | #6 |
Rep 234
I told the mechanic about it, tire pressure seems ok, camber, control arms does not have any problems. Yet my car always tend to lean left on the highway. The car tends to want to move all over the place rather then on a straight line. Turning also dosen't seem very accurate, hard to place the car on the road sometimes. Hmmmm...what could be the problem?
06-07-2010, 01:02 AM | #7 |
143
Rep 2,957
Drives: E90 330i Monaco Blue/Beige
but your mechanic could not provide u any clue?
btw, will it because you still not yet get used to the driving on the left? just guess
E90 330i VB32 Monaco Blue/Beige/BurledWalnut - Prodrive GC-014I Forged 18" 8.5J/9.5J British Black + Michelin PSS 225/255 + Bilstein PSS10 + H&R ARBs + ACS bodykit + Brembo Gran Turismo Brake Kit 355-6F/345-4R + Rogue Engineering IKON exhaust kit + Simota Intake V2 + MFD Scoops + Blackline w/ red bulbs + PIAA H11 4700K fog + PIAA 6500K White Angel Eyes + MTEC 7000K license plate LED + GS-55 front doors LED + Valentine-1
06-07-2010, 05:13 AM | #8 |
Rep 234
The mechanic's english was terrible and my Chinese isn't good enough, even when trying to explain the above techincal terms. I also noticed my steering has gone rather light and soft on straight sections. Maybe it has something to do with the toe/caster angle as well as the steering, wonder what would cause that. My car has a little over 30,000 km, so it's not that much to have cause problems with things breaking down and all.
06-07-2010, 10:41 PM | #9 |
Rep 2
Oversteer is "Lud Mei"
Understeer is "Tui T-Au" Do you own your car since it was brand new or did you recently buy it as a used one? Sounds like you have an alignment problem but could elaborate to frame integrity, tires condition and steering. My 2 cents. |
06-10-2010, 02:14 AM | #11 |
Rep 234
Through the translator, the mechanic mention something about uneven tire wear. I'm gonna rotate the tires in that case, I can rotate the run-flat like regular tires right?
08-11-2010, 01:40 AM | #12 |
Rep 393
yes.. u can.. i have understeering issue too.. it's because of your rear griper than front.. try to run fatter tire in the front or lesser in the rear
08-11-2010, 09:07 PM | #13 |
Rep 234
Thanks, I did the tire rotation myself (well with a bit of help from a local mechanic in balancing the tires) but that saved me a bundle.
11-30-2010, 01:16 AM | #14 |
Rep 1
02-08-2012, 10:12 AM | #15 | |
Rep 78
02-09-2012, 03:10 AM | #17 |
Rep 741
