E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Any harm leaving a USB drive plugged in?
Reply
      04-21-2010, 11:39 AM   #1
joelc73
Drives: 2010 E90
I've been using a thumb drive in the center console. I love the flexibility of having a large (relatively) 32GB drive in there rather than my iPod.
I notice the light stays on on the USB drive itself. I'm assuming, therefore, it's drawing power. Is that a problem at all?
The reason I stopped using the iPod was that I noticed it too was also always on. Or at least I assumed it was as the charge indictator was on. It just bothered me that it was drawing power when the car was off.
Thanks
JC
      04-21-2010, 12:57 PM   #2
DrMooCow
Drives: 335d
No, it will be fine. The power draw from the usb drive is very small. If you're that worried, you can always unplug it?
      04-21-2010, 01:01 PM   #3
Tee212
Drives: yes
2010 335  [8.00]
I have a 16g stick in there for the past 5 months with no issues however this flash has no led. Had i known youre able to just use a flash drive for mp3s I would of never bought an ipod and its pretty much worthless to me right now.
      04-21-2010, 01:08 PM   #4
Whostheboss
Whostheboss's Avatar
410
Drives: a 9incher
Ive Been using a USB flash Stick for over a year now and no problem. It's easier than iPod. If you have a Standard USB cable you can charge Some devices. I can charge my Blackberry and PlayStation 3 controller while car is running.
(The PS3 controller is not essential, but im just saying)
WHO'S THE BOSS
      04-21-2010, 02:05 PM   #5
joelc73
Drives: 2010 E90
Cool - it sounds like leaving it plugged in isn't a major concern at all.
Thanks!
      04-21-2010, 02:06 PM   #6
joelc73
Drives: 2010 E90
What's the PS3 controller being used for?
      04-21-2010, 02:09 PM   #7
Whostheboss
410
Drives: a 9incher
nothing, i was just testing and playing with all kinds of devices that the center console usb port can recognize.
The USB port in the center console is 2.0 so by default is passes a 5.0 volt to any device, i can charge the blackberry and even charge a Playstation 3 controller.
the Ps3 controller is irrelevant i was just using it as example
WHO'S THE BOSS
      02-05-2011, 07:43 AM   #8
amullo
Swedish F31 lightenthusiast
amullo's Avatar
48
Drives: BMW F31 320d xdrive Msport
So I could buy a cheapo USB cable, plug it into the USB socket and charge my phone while I´m driving (my phone takes micro USB).
That´ll save me a few bucks on a 12v charger...
Not that it matters much, I´m just asking..
//amullo
-17 F31 320d xdrive Msport
-10 Ducati Multstrada 1200s
      02-05-2011, 02:46 PM   #9
wren57
Roll Tide
wren57's Avatar
591
Drives: 335i
I might be wrong, but I don't think the USB drive has enough voltage to power a phone.
Fix your broken/stripped cowl bolts with this elegant brass solution!
http://www.e90post.com/forums/showthread.php?p=20230306
      02-05-2011, 04:52 PM   #10
javaperson
Drives: 2021 G05 X5
The USB port should be fine for charging a phone. It'll charge the ipod when that is plugged in. The USB port will run at ~5Volts, but the only concern is how much current it can deliver. Not sure about the BMW port, but some USB ports may be limited to delivering 500mA, and some USB devices (maybe some phones) may require 1A.
      02-06-2011, 01:11 AM   #11
ergoyo
ergoyo's Avatar
92
Drives: 2022 X3 M40i
I have a random question for those using the USB flash drives for music.
When playing a song and turning the car off, when you return to the car, I know playback is resumed of the same song, but, can you still return back to the artist/album, etc? When I try going back it sends me all the way to the top, or "A" artists, and this is really annoying since I need to turn the idrive wheel a million times again to make it to the last artists/albums, etc. And then repeat this same routine everytime the car is turned off.
      02-07-2011, 06:11 AM   #12
amullo
amullo's Avatar
48
Mine seems to restart on the beginning of the song it was playing when i turned the car off just like yours.. Not sure on the other thing. I´ll have to RTFM..
//amullo
Reply
e90post
