E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY - Removing / Replace Roundel (roundel removal)
Reply
      11-16-2006, 01:28 PM   #1
Jason
Administrator
Jason's Avatar
Drives: F80 M3
One easy way to improve the apperance of your BMW is to replace a worn or faded Roundel. In this tech article we will discuss replacement of the roundel, and should take less than 10 minutes to perform. What you will need is a new Roundel and two plastic grommets, (available from Pelican) - shown in Figure 1 and Figure 2.
The first step is to remove the existing Roundel. As you can see in Figure 3, the existing Roundel is worn and fading. The method of removal varies, but the end result is the same, you must gently pry the old Roundel off. In this case we simply used a credit card as a fulcrum point, then inserted a flat-head screwdriver between the Roundel and the hood. Remember to use caution when prying off the old Roundel. Go slowly and using light force, and it should come right off. (Figure 4)
Step two is to remove the two grommets left behind sitting in the hood as shown in Figure 5. If your grommets came off with the Roundel, you can skip this step. Simply remove them with a pair of pliers, they should pop right out. This is also a good time to clean the base for the Roundel, for as you can see it is covered with dirt.
Next, simply push the new grommets onto the new Roundel as seen in Figure 6. You may have to use a little force to get them on there, but use caution as it is possible to break the studs they slide on.
Finally, simply line up the studs with the corresponding holes in the hood, and press down with the palm of your hand, til the Roundel goes no futher (Figure 7). That's it, you're done!
From : http://www.pelicanparts.com/bmw/tech...30-Roundel.htm
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook
Follow us on Bimmerpost Twitter
Subscribe to Bimmerpost Youtube Channel
      11-16-2006, 01:41 PM   #2
sstarch1
From Russia With Boost
sstarch1's Avatar
36
Drives: E92 335i - Vroom
2007 335i  [0.00]
I will try to remove the rear roundtell on my trunk this evening, but i assume there will be two holes left...any way to cover them up?
2007 BMW 335i - Delivered 9/8/06
Sparkling Grpahite with Black Leather/Aluminum Trim
Premium Package, Sports Package, Comfort Access.
      11-16-2006, 03:20 PM   #3
Chesmu
Chesmu's Avatar
Drives: 2013 X6
2006 330i  [0.00]
2006 330i  [0.00]
yeah... with a new roundel....
not only will you have two holes, but you'll also have a circular divot in the trunk lid where the roundel fits. Put on a new one .....
see this thread:http://www.e90post.com/forums/showth...lacing+roundel
"Teach the ignorant. Ignore the stupid."
      01-12-2007, 11:33 PM   #4
King335i
King335i's Avatar
Drives: '13 E92 M3 CP 6MT, '13 X1 35i
I tried this on a E92 coupe and I don't know if I simply didn't apply enough elbow grease or what, but the roundels seemed like they did not want to budge at all and I was worried about damaging them. What am I doing wrong? Has anyone done this on an E92 coupe?
2007 E92 335i--SG, Fully loaded, minus the dead weight..err..iDrive and Active Steering.
      01-13-2007, 12:01 AM   #5
Chesmu
Chesmu's Avatar
Drives: 2013 X6
2006 330i  [0.00]
2006 330i  [0.00]
careful... check out Picus's thread on "problem with e92 roundels". In summary, the replacements might not fit correctly on the coupe
      01-13-2007, 02:18 AM   #6
ironic
ironic's Avatar
Drives: Jet Black 335i
Damn those roundels are worn, i had a 5 year olf 328ci, i know not that old, but the roundels were in perfect shape, do they relaly wear that fast?
Widebody 335i Project Car BUILD | PHOTOSHOOT
      02-01-2007, 06:08 PM   #7
picus
picus's Avatar
125
Drives: e92 SG 335i Coupe
The front was a breeze for me, the rear was a huge pain in the ass. Of course there are no replacements for it yet either. A 72mm one might work, but it won't fit perfectly.
      02-05-2007, 08:35 PM   #8
calvino
Drives: had e90, 330i mystic blue
2006 e90 330i  [0.00]
does anyone knows how to remove the Roundel of the steering wheel? mine is all mess up but I'm scare of trying to remove it I don't want to set off the airbag or something like that
E90 Mytic Blue 330i 07-20-2006. 05-17-2011
Doesn't the idea of making nature against the law seem to you a bit . . . unnatural? Support NORML
      02-05-2007, 08:39 PM   #9
Chesmu
Chesmu's Avatar
Drives: 2013 X6
2006 330i  [0.00]
2006 330i  [0.00]
i just stuck my replacement on top of the original. Looks fine to me. Ksfrogman says that there are clips on the side of it.
      02-05-2007, 09:22 PM   #10
calvino
men I'm so fucking stupid !!! there are NOT clips on the inside of the roundel of the steering wheel I bend it and I had to remove it aI'm clad I had a ACS one but now I don't like it that much it dosent look like BMW I don't think I can buy one at the dealer so I guess I have to get it on ebay
so guys DO NOT remove the one on your steering wheel just put a new one in top of it.
      02-05-2007, 09:42 PM   #11
///Matt
United States Marine
///Matt's Avatar
Drives: 2007 Dodge Ram 1500
2006 330i  [0.00]
The steering wheel emblem is NOT replaceable, according to BMW. I've replaced many complete airbag's for a damn cracking emblem. It's DUMB.
      02-05-2007, 09:48 PM   #12
calvino
I'm SOOOOOOOO STUPID !!! I f up my original emblem !
no wonder why went I was trying to remove it I hear a crack and I saw the center of my emblem broken!
I guess now I will have get one on ebay
or get another airbag matt can you hook me up with an airbag ?
      02-05-2007, 09:54 PM   #13
joebaggg
E60
joebaggg's Avatar
Drives: Black Attack
2006 E90  [0.00]
why replace them... the bimmian cover ups look great, most cant even tell theyr stuck on there. for 15$ you cant go wrong
      02-06-2007, 07:41 AM   #14
canucklion
pull my finger to get your kinder® surprise
canucklion's Avatar
148
Drives: circles around you
that sucks man, calvino, it'll be easier for you to get hte Ebay ones, instead of replacing your airbag, that'll cost you $$$$$$
      02-06-2007, 09:23 AM   #15
calvino
yea I was j/k I can use $800 for a set of wheels instead of a new airbag
howeverr look the emblem that I found I love it
      02-06-2007, 10:01 AM   #16
ADHD
ADHD's Avatar
Drives: F30 328i
21 M540i  [0.00]
07 e90 335  [0.00]
WOW!! i would NEVER use a screwdriver to remove the roundels!! Holy shit u guys are nuts!!! just use dental floss guys much easier and guarannetted NO scratches or dents
      02-06-2007, 10:49 AM   #17
ksfrogman
ksfrogman's Avatar
Drives: E90 330i 6MT
2006 330i  [0.00]
2006 330i  [0.00]
There are clips on the steering wheel emblem. Just don't plan on reusing your existing roundel. I replaced mine with a new one that was black/white.
Like any other item you attempt to remove, don't force anything and take your time. If you use a screwdriver, see where the plastic is pulling up, and redirect your prying using those spots as fulcrum points.
      02-14-2007, 03:40 AM   #18
sp8w
Always Lurking
sp8w's Avatar
Drives: E60 M5
2007 M5  [0.00]
2007 E90 335i  [0.00]
A friend at the dealership offered me a great suggestion. When I went in to get a new roundel, he asked if I would like to borrow their high-tech tool to remove the old roundel. j/k
He went in the back and cut a piece of nylon strapping that they use to band pallets. It worked great because it was thin enough to get behind the roundel and strong enough not to break.
2007 M5 - Black Saphire | Black
2007 K1200R Sport - White-Aluminium Metallic
2007 335i - Sparkling Graphite | Terra (Retired)
      02-14-2007, 11:46 AM   #19
ADHD
ADHD's Avatar
Drives: F30 328i
21 M540i  [0.00]
07 e90 335  [0.00]
^^^^^ thats exactly how i use the dental floss!!!! great pic bud
      02-14-2007, 02:04 PM   #20
Hunter399
Hunter399's Avatar
325
Drives: F90M5
I wrapped the screw driver blade in a MF towel
Works perfect, no problems at all
      02-14-2007, 02:29 PM   #21
Paul330d
Torque junky
Paul330d's Avatar
France
115
Drives: Remapped e90 330d
2006 330d  [0.00]
2005 Fiat Panda 4x4  [0.00]
Now that's a good idea. Thx for sharing
www.greenkeepers.fr - spécialiste des tondeuses à gazon hélicoïdales atco qualcast ransomes lawnflite
      03-30-2007, 03:09 AM   #22
j|rz44
43
Drives: 335i|E92
07 335i  [0.00]
i just installed my hood roundel...
used dental floss to lift, slid the credit card in and went to the screwdriver...
i didnt attemp to do the trunk, as the roundel seemed diff., the top and
bottom lip were thiner than the side edges...
can someone please post a pick or share their experiences...
picture wouldnt upload...ill try again later
thx
Life is Good
Reply
e90post
