CD73 (Professional) Wires Diagram
01-22-2010, 01:05 AM | #1 |
Rep 71
Hello people!
I need the wire diagram or the meaning of the pins on the back of the CD player CD73 Professional . I searched here : http://spaghetticoder.org/bmw/wds/e90/ but no diagram appears to me,i also installed java. I need to know which are the speaker pins ,the positive and negative ones and the others too. Thank you!
02-04-2010, 09:40 AM | #2 |
freude am fahren ....scheiden freude...
17
Rep 299
nobody on his pc has got adobe svg 3.0 viewer....try to install it from adobe ...it's freeware and then you can see about anything...
02-04-2010, 09:52 AM | #3 |
2309
Rep 13,018
1 Signal, AF radio, rear right + 2 Signal, AF radio, front right +3 Signal, AF radio, front left + 4 Signal, AF radio, rear left + 5 Signal, AF radio, rear right - 6 Signal, AF radio, front right - 7 Signal, AF radio, front left - 8 Signal, AF radio, rear left - 9 Signal, CAN LOW bus CAN-bus 10 Signal, SIM card Telephone transceiver 11 Signal, CAN HIGH bus CAN-bus 12 Ground 13 Aerial switching signal 14 Signal, dimmed instrument lighting 15 Supply, terminal 30 Fuse F40 16 Not used |
