DIY: BBK (big brake kit) for e90/e91/e92/e93
10-22-2006, 11:31 PM | #1 |
1433
Rep 16,628
yo guys, here is a DIY big brake kit for e90/e91/e92/e93. i am going to try my best do explain what i did. everything was easy. the only thing i thought would be hard is bleeding the brakes. if you know how to bleed the brake line, you are good to go.
tools needed:
remove 2 18mm bolt thats hold the caliper. you can remove the caliper and use some zip ties to hang it somewhere. say hi to me loosen the 6mm hex on the face of the rotor remove the rotor. now pinch the brake line with the pincher. with a 14mm open end wrench unloose the brake line from the caliper. now you should have everything off. trim the corners with the dremel so the bigger caliper can clear the heat sheild. before after now reverse the install with the bbk. install the stainless steel brake lines if your kit comes with them. here some pictures putting the BBK on. tight the brake line on the caliper first and find something to hang it. now install the rotor. bolt the caliper on. the brake sensor does not work in BBK. just zip tie the sensor somewhere, so it wont get tangle while you are driving. now bleed the brakes. have fun!!! thanks ///Matt :rocks: |
10-23-2006, 12:11 AM | #3 |
3278
Rep 6,726
As I was looking at the pictures I was thinking how in the hell can Long spend SOOOOO much time keeping EVERY SINGLE BOLT CLEAN LIKE THAT?!!!
And then I saw his hub with NO RUST and I thought he hand cleaned them down. Funny Last picture was a 335!!!! THAT explains it ALL Great DIY man. GF can brake on a dime now! |
10-23-2006, 01:09 AM | #4 | |
Rep 1,024
330i Monaco Blue, Terra /w aluminum trim, SP, PP, CA, PDC, Nav, Folding Seats, Sat Prep European Delivery Blog Picture Gallery |
10-23-2006, 01:12 AM | #5 | |
1433
Rep 16,628
10-23-2006, 10:30 AM | #8 | |
1433
Rep 16,628
10-23-2006, 10:45 AM | #10 |
Moderator
497
Rep 27,441
nice!
10-23-2006, 11:31 PM | #11 | |
89
Rep 3,011
15 bucks.
"Teach the ignorant. Ignore the stupid."
10-24-2006, 12:47 AM | #13 | |
150
Rep 2,419
It's a great time to be alive
10-24-2006, 01:04 AM | #14 |
15
Rep 465
Nice mod Long... where did you get them??
BMW E90 325i Monaco Blue - Beige Dakota, Steptronic, Premium Package, Adaptive Xenons
MODS: AC Schnitzer Body Kit, 19" CSL Wheels, Quad Exhaust ,Aluminum Pedals and an E92 |
10-24-2006, 01:22 AM | #15 | |
1433
Rep 16,628
12-05-2006, 11:22 PM | #22 |
Model
23
Rep 283
Drives: Fast and Loud
Garage List 1999 M3 [0.00]
2001 ML55 AMG Desig ... [0.00] 2001 BMW X5 4.4 (SOLD) [0.00] 2003 VW Jetta 1.8T ... [0.00] 2007 335i (SOLD) [0.00] 1966 Pontiac GTO [0.00] |
Great job man.
So $3400 for just the fronts? There no way. What brand is it? I see JBT written on the rotor, but I've never heard of that company. I'm sure Brembo will come out with an application for e92's. How does it perform now?
“No man has the right to be an amateur in the matter of physical training. It is a shame for a man to grow old without seeing the beauty and strength of which his body is capable.” ~ Socrates
