E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Africa > Custom Sub Box Install
Reply
      04-14-2009, 07:08 AM   #1
Menno11
Member
Menno11's Avatar
South Africa
35
Drives: 320d
2005 320d  [0.00]
Howit fellow E90/E92's
So the Long Easter Weekend was more than enough time to finally build the Sub Woofer enclosure I have planned for SO long! The Enclosure is for a Pioneer 12" 800W SVC (the original before the gray products started rolling in)
First off, I built up the rough shape with Pine boards, this was a pain in the arse as the wheels arch is a complex shape of curves.
Name:  Sub Install01.jpg
Name:  Sub Install03.jpg
After I had ensured that I had the right shape and a tight fit, I started with the fiber glass around the shape. About 4 - 5 layers gave the right shape and hardness I wanted for the box.
Name:  Sub Install04.jpg
Then I made sure that all wiring was still good on the amp I installed bout 4 months ago, also put in a remote on/off switch for when the in-laws are in the car.
Name:  Sub Install05.jpg
Decided to carpet the entire box for the more stealth look, got the carpet at HI-FI Corp and so, the final product looks something like this.
Name:  Sub Install06.jpg
Name:  Sub Install07.jpg
Name:  Sub Install08.jpg
And what does it sound like I hear you asking. Awesome!! It bangs for sure!! I played around with the crossover for a while to get the right integration point and sounds sweet now. After driving around with it for half a day, decided to drop the gain a bit as the base was drowning out the treble, but a couple of settings on the gain, combined with pushing the treble up has left me with a much rounder sound and fuller sound spectrum.
      04-14-2009, 08:26 AM   #2
rennzport
Drives: bmw
you've been busy!
hav you thought about using supa wood?
      04-14-2009, 10:06 AM   #3
Menno11
Member
Menno11's Avatar
South Africa
35
Drives: 320d
2005 320d  [0.00]
Because I was going to fiberglass, I used any available wood in my garage just to get the basic form to fiberglass around. The glaas fiber gives the final strength and form, whilst the pine is soft enough to easily cut and sand.
      04-17-2009, 09:36 AM   #4
mommet
mommet's Avatar
Drives: E90 325
still can't figure, how did you connect the amplifier to the standard sound system?
07 E90 325 sports pack - Silver
Ex's
05 Golf 5 Gti - Silver
04 Jag X-type 3litre - Silver
00 Corolla RXi - Silver
      04-17-2009, 10:03 AM   #5
Menno11
Member
Menno11's Avatar
South Africa
35
Drives: 320d
2005 320d  [0.00]
You use a Line out Converter (LOC) that converts the signal going to the speaker wires into a 5 volt signal that can enter the amp at RCA level. No cutting of wires, just purely an add-on. The sound is so much fuller now, brilliant!
      04-17-2009, 01:20 PM   #6
rennzport
Drives: bmw
plz show me on saturday.
i wanna upgrade my crap sound
      04-20-2009, 06:19 AM   #7
mommet
mommet's Avatar
Drives: E90 325
Red face
have you got a picture of the cable?
basically you connected this wire to a speaker and then on the other end there is RCA's that connect to the amp
how does the on/off signal work?
sorry.. don't know much about this.
Ex's
      04-20-2009, 09:16 AM   #8
Menno11
Member
Menno11's Avatar
South Africa
35
Drives: 320d
2005 320d  [0.00]
Hi Mommet,
here is the LOC that I used: Its the NR-300
http://www.audiopipe.com/images/catalog/89.jpg
Check my other blog in the Africa section that has my Amp install detailed.
I have the remote connected to the CD changer cable cluster's remote-on and I just added an optional on/off switch for when I dont want all that bass (like when the in-laws are in the car!)
If you dont know that much about sound, rather take the car to a sound shop to help you install! You can buy all the component and have them install to save those precious Rands!
Reply
e90post
