      05-23-2025, 06:27 PM   #1
Gt4
Gt4's Avatar
63
Drives: 2006 E46 M3 Estoril blue 6mt
2006 BMW E46 M3 Coupe 6mt Individual Estoril blue / Nappa black
USD 61,000.00
Individual package (similar to Porsche Paint To Sample program)
Estoril blue
Black leather
6 speed manual from factory
Cold Weather package
Harman Kardon stereo
Titan shadow trims
Xenon Headlights
Canadian car
Mileage: 97000km or 60625miles
Car is located in Montreal, Canada
Modifications:
Exterior
-OEM euro front bumper (no amber reflectors)
Wheels & tires
-BBS LM 148 & LM 165
19x8.5et32 front & 19x10et25 rear
Gold hardware
Genuine BBS Blue / Gold center caps
-Brand new Continental Extreme Contact DWS06 235/35/19 & 275/30/19
Suspension
-Ohlins DFV Road & Track coilovers
-Dinan camber plates
-OEM E46 M3 CSL 22.5mm rear swaybar
-OEM E46 M3 Convertible 27mm front swaybar
-OEM ZCP/CSL 14.5:1 steering rack / blue tag with DSC coding done accordingly
-OEM front & rear strut tower reinforcement plates
Brakes
-OEM ZCP/CSL brakes (carriers & rear calipers)
-OEM ZCP/CSL cross drilled rotors
-OEM CSL pads
Interior
-OEM ZHP shift knob/leather shift boot
-AKG DSSR
-BMW Performance pedal covers
-Armrest delete center console
-OEM AUX input jack
-Bosch CSL/Mini size battery
-AKG delrin clutch/brakes pedals bushings
-New OEM floor mats
No test drive. I am available any time if you want to schedule an inspection at a BMW Dealer in the Grand Montreal area.
Asking price: 85000$ CAD
I am selling my 2006 BMW E46 M3 Individual package with 6-speed Manual transmission from factory. Car currently has 97000km. I am the third owner and bought this car in 2018. Previous owner had the car for 9 years. No accident, clean Carfax. No lien on vehicule.
All panels and glasses are original except for the new Euro front bumper. Euro front bumper was painted at a BMW dealership.
Color combo is Estoril Blue Metallic (335) on Nappa black. Only 6 cars were built with this color combo for Canadian market with the 6 speed manual transmission and 10 for the US market. There was a total of only 58 Estoril Blue Metallic cars made for North America (all color combo combined) and probably half of them were equipped with the SMG transmission.
Car was built on April 2006, making it one of the last E46 M3 out of the assembly line.
The most rare option in this car is the option S778A - Individual BMW identification door sills. It was installed on 56 out of 26,202 cars (only came on Canadian Individual package E46 M3). So 1/56 Canadian Individual package E46 M3 Coupe/Convertible.
It has the rare gloss Shadowline exterior trims and also has an engine bay and hood underside color match & clear coated from factory. Only few Individual package cars has this feature.
Maintenance done during my ownership:
-Liquimoly 10w60 engine oil/Mahle filter
-BMW SAF-XJ + FM Booster 75w140 diff fluid
-BMW MTF-LT-2 tranny fluid
-Motul RBF 660 brake fluid
-BMW Long-term coolant
-Pentosin CHF11s power steering fluid
-2 Airbag recalls done
-New RE Rod bearings with ARP bolts
-New OEM oil pan gasket
-valves adjustment done
VANOS bulletproofing :
-Beisan anti-rattle kit with new bearings
-Beisan VANOS seal kit
-Beisan seal plate kit
-OEM VANOS metal gasket
-VANOS unit cleaned
-VANOS line changed with oem update part
-VANOS filter changed
-OEM torx bolts
-Beisan chain guide tensionner
-VAC Motorsport exhaust hub
-OEM valve cover gasket
-CMP RACP aka ‘’rear subframe’’ underside reinforcement plates welded
-CMP aluminum subframe bushings
-New Guibo disc
-driveshaft center bearing & centering sleeve
-New NGK spark plugs
-New Bosch ignition coils
-New OEM engine mounts
-New FTE clutch slave
-New OEM 850i Stainless steel pivot pin
-New E21 transmission mounts
-New LuK clutch, pressure plate & flywheel
-New OEM clutch fork & bearing
-Belts replaced
-New CPV o-ring
-new selector rod seal
-new shifter bushings
-New Lemforder front control arms bushings
-New Lemforder rear trailing arms bushings with limiter shims
-new OEM power steering hoses
-New exhaust gaskets between headers & section 1 and also between section 2 & muffler
-OEM Section 1, 2 & muffler been cleaned and polished
-new fogs lights, clear corners and side markers
-ICV cleaned
-ITB cleaned
-MAF cleaned
-new OEM oil filter housing gasket
-New fuel filter and new regulator
-New water pump, coolant overflow tank, thermostat, hoses
-New Valeo Starter
-New Valeo alternator
-new OEM fuel pump
-new OEM TPS sensors
-new OEM accelerator pedal
-new OEM intake/exhaust camshafts sensors
-NEW Bosch O2 sensors
-new OEM knock sensors
-new OEM crankshaft sensor
-New BMW emblems front & rear
-New ///M3 badge on trunk
-New OEM kidney grills
-New OEM side grills
-New OEM hood grill
-New sunroof felt seal trim
-New OEM steering wheel guibo
Pictures can be seen here:
https://nam3forum.com/forums/forum/c...ue-nappa-black
      05-26-2025, 07:29 PM   #2
JRF
Drives: Raptor, S5. Past E36/46/92, M2
can't view pics at that link without permissions
      05-26-2025, 09:41 PM   #3
Gt4
Gt4's Avatar
63
https://www.kijiji.ca/v-view-details...dId=1717601593
      06-08-2025, 08:25 PM   #4
SD46+80
SD46+80's Avatar
Drives: 2003.5 e46 m3
Gorgeous. GLWS.
      Yesterday, 06:50 AM   #5
Gt4
Gt4's Avatar
63
Originally Posted by SD46+80 View Post
Gorgeous. GLWS.
Thanks
