01-23-2025, 06:30 AM | #1 |
![]() ![]() ![]() ![]() ![]() 63
Rep 902
FS: Complete BMW E46 M3 S54 engine with accessories
Engine pick up in Montreal, Quebec. Can deliver in Quebec, Ontario, Maritimes provinces for extra $$$ I am selling a S54 engine out of a 2002 E46 M3 6mt with 220000km. Perfect setup to swap a E46 non-M. I did the following maintenance to this engine and 0km since: Fresh paint on the block Valve adjustment done VANOS bulletproofing done with the following: -Beisan oil pump disc (redrill) -Beisan anti rattle / new bearings -Beisan seal plate -Beisan Vanos seal -Beisan chain guide -Beisan Vanos solenoid rebuild -New sprockets bolts -New hubs bolts -New valve cover gasket Rod bearings replaced: -ACL rod bearings standard size -new OEM oil pan gasket -new OEM oil pick up strainer gasket -Rear main seal and gasket replace New oil filter housing gasket Throttle bodies removed & cleaned Idle control valve cleaned Intake manifold cleaned Comes with: -Engine wiring harness -intake manifold -Bosch Ignition coils -OEM airbox with MAF -OEM radiator & hoses -OEM oil cooler -OEM power steering cooler -flywheel -engine mounts -o2 & EGT sensors -fan shroud -secondary air pump & valve -coolant overflow ressevoir -starter -fuel pressure regulator -... Price: 9000$ cad Catless headers SoLD, can included OEM headers with cats removed Last edited by Gt4; Yesterday at 06:52 AM.. |
