12-18-2024, 06:42 PM | #1 |
Rep 4
For Sale: WTS/WTT 2003 BMW M3 (Titanium Silver, 167K Miles, LOTS of Maintenance/Mods)
For Sale: 2003 BMW M3 (Titanium Silver, 167K Miles) TL;DR: Big 3 Maintenance: 2 of 3 done (Rod Bearings and Subframe Reinforced) Extensive maintenance history and upgrades, with receipts and an Excel log of modifications. Turnkey condition; ready to drive cross-country. Open to trades for other M Cars (preferably E9x, but open to offers). Maintenance Engine & Drivetrain: Rod bearings replaced twice: under recall and again at 127K miles (Lin’s Automotive). Subframe reinforced in 2021 (Lin’s Automotive). Manual swap completed at 145K miles using OEM parts, including a new LUK clutch and flywheel (Lin’s Automotive). Valve cover gasket, valve adjustment, and spark plug gaskets replaced (Euroworks). New fuel pump and fuel filter. Driveshaft rebalanced; new center support bushing and guibo. New 80K-mile differential from ZCP, fully refreshed with new pinion seal, side seals, bolts, and bushings. New starter and alternator. All pulleys and belts replaced. Suspension & Steering: New Bilstein B16 suspension with Ground Control camber plates. Synchro Design Works rear trailing arm bushings. New tie rods (OEM). Brakes: Ceramic brake pads (all corners) with new front rotors. Brake fluid flush (ATE brake fluid). Cooling System: Mishimoto electric fan conversion. Coolant flush (BMW coolant). Other: Fully refreshed axles (new boots, grease, and joints). New spark plugs, ignition coils, and injector O-rings. New air rail O-rings. New rear wheel bearings. New wheel speed sensor. Modifications Exterior: Paint corrected and ceramic coated with G Technique Exo V5. Advan RS2 wheels with brand new Firestone Indy 500 tires (255/35/18 square setup). Interior: OEM NLA purple M-stripe floor mats. Patina Research cupholder. Euro center console. Alcantara armrest. ZHP shift knob. ZCP shift boot. Performance: Gruppe M intake. Dinan muffler and OEM section 2 exhaust. Hotchkis front sway bar. Motorsport Hardware stud conversion. Dinan front strut bar. Additional Details Miles may increase slightly as the car is occasionally daily driven. Binder of receipts dating back to 2018 and detailed Excel file tracking all modifications available for serious buyers. Cons: Sunroof doesn't work; I planned to replace it with a sunroof delete panel, so I never bothered fixing it. Typical E46 slightly saggy headliner. A few rock chips on the front bumper and hood. Two minor accidents on Carfax from 2009. Appears to have been a fender bender, as the car was able to drive away under its own power. If you're interested or have trade offers, contact me for more information! 770-990-477 Link to more photos:https://drive.google.com/drive/folde...Tq?usp=sharing |
