09-08-2024, 08:48 AM | #1 |
12834
Rep 2,737
Home Speakers
About to pull trigger on Sonos for our home, curious if someone else here has already done the research of what setup to go with. Open to other brands but from what I’ve heard - Sonos’s sound is a great mid-$range value for the average home user.
09-08-2024, 10:08 AM | #2 |
Rep 636
I have a bunch of Sonos Play 1's. I have a few sets outside under the eves and I am very happy with them for back ground music. My buddy has a bunch of Sonos as well, he added the Sonos subwoofer and it is his primary listening system. He's very happy with it.
floridaorange12834.00 |
09-08-2024, 11:24 AM | #3 |
BMW Owner Since 1971
2556
Rep 1,541
Drives: 1964 700 Sport Cabriolet
All depends on how picky your ears are! These are about 1/3 of my speaker stash.
DrVenture1446.50 Marmugmotleocay1826.00 floridaorange12834.00 FrankDK208.00 eliphil2758.50 RickFLM411978.50 Bingham274.50 |
09-08-2024, 01:23 PM | #4 |
4310
Rep 5,742
Drives: 2019 M2 Competition
what's the purpose of the speakers?
home audio/tv or music? can't go wrong with sonos though. |
floridaorange12834.00 Murf the Surf22127.50 |
09-08-2024, 02:15 PM | #5 |
1447
Rep 424
For a whole house solution that is integrated and wireless, I don't think you can go wrong with Sonos.
I don't own any, but have a Play 5 1st gen disassembled on my workbench right now for a replacement of a faulty resistor in the amp section. The construction is impressive. I have too much other equipment (systems) in various spaces throughout the house to make Sonos a good option for me.
Carbon Black - Debadged|Mocha Nappa|DHP|DAP|Premium Pkg|Luxury Seating|M668 w/ DSW06+
09-08-2024, 05:22 PM | #6 |
6492
Rep 3,299
Drives: 2024 M340i xdrive
I wanted a wireless solution so I can vouch for Sonos as well.
I have eight play3's, playbar, sub and an amp so i can use my turntable. Are they the best speakers you can buy, no, they're a long way from it but they are wireless and do a pretty good job. |
09-08-2024, 08:38 PM | #7 |
Rep 1,003
We have a bunch of Sonos but all the S1 version (not compatible with the newer app and the old app is not compatible with the newer speakers). I’m too cheap to replace them all (2-1, 2-3, 3-5, sub, soundbar) so I’m frozen (not going to run two setups through two different apps). Every now and then some of the older ones come up for sale on FB marketplace so I might snag them that way.
Other than that issue, very happy with the sound and performance. So much easier than wiring speakers (they do have to have a power connection, just not a speaker wire) |
09-08-2024, 08:45 PM | #8 | |
Rep 31
Were you a JBL dealer in the past, or JBL shareholder? |
09-09-2024, 06:26 AM | #10 | |
Rep 636
floridaorange12834.00 2000cs4021.00 |
09-09-2024, 11:39 AM | #11 |
2556
Rep 1,541
No, but my Dad bought his first JBL mono speaker (15-inch 2-way 030) back around 1957 and I still have it today. You could say I've grown up with them over the past 65+ years. I just like 2-channel stereo. Not into surround, or wireless, or even subwoofers.
Today these are the speakers in my main system: |
09-09-2024, 02:09 PM | #12 | |
12834
Rep 2,737
standing? |
09-09-2024, 04:03 PM | #13 |
6492
Rep 3,299
floridaorange12834.00 infinitekidM2C4310.00 |
09-10-2024, 12:28 PM | #14 | |
5586
Rep 3,360
With that said, I listen to stereo (2 channel) only recordings via an audio processing algorithm called Trifield. Trifield goes about taking a two channel source to anchor the center image of the music presentation. It utilizes all 5 channels in a base multichannel system with the predominant sounds coming from the front speakers (L, R, center). The center channel has the majority of the audio output with the rears as fill in for ambience. In my two channel only system, I still use Trifield as it expands out the soundstage over just listening to straight stereo. The unfortunate part of Trifield is it seems Meridian Audio is the only manufacturer where you can get this processing. With subwoofers, I used to have the same opinion as you until I got a proper subwoofer and spent the time to properly integrate it into my system. Now I will never have an audio system without a proper sub. The benefits are numerous with a properly integrated sub. One more headroom with musical peaks; especially at higher volumes. Less distortion both from the mid bass on up and also on down. Subs are purposely designed to handle low frequency reproduction. With proper bass reproduction, you have to move volumes of air. Few "full range" speakers have woofers that can move that kind of air without distortion or extension down below 30 Hz. Subs can also be placed in spots in the room where bass reproduction is best where it wouldn't be ideal for other parts of the frequency range....not to mention the spot may not be ideal for proper soundstaging relative to your listening position. Adding a powered subwoofer will also provide biamping benefits without the complexity to do actual biamping. My two channel system has a single 12" Velodyne HGS12II with a SMS-1 EQ. My multichannel system has two Velodyne subs: an HGS15II and a DD18. 15" and 18" drivers respectively. The HGS15II has an SMS-1 EQ and the DD18 has the same EQ but built in. I have the system set up where the HGS15 handles frequency reproduction from 40 to 80 Hz and the DD18 handles from 40 on down. The results have been amazing where I've received positive feedback from those that have heard the system. I've also done in room acoustical treatments which is an area that many people overlook. |
09-10-2024, 12:58 PM | #15 | |
Rep 31
Looks like they're in excellent shape, did you have to rebuild Xovers and refoam the drivers? |
09-10-2024, 01:12 PM | #16 | |
Rep 31
09-11-2024, 11:48 AM | #17 |
2556
Rep 1,541
As JBL only made 200 pair of the 4345, these are "clones" with cabinets made by the US cabinet maker for Kenrick sound in Japan. Populated with refurbished JBL drivers and custom-built charge-coupled crossovers which avoid the bi-amp switch which was problematic in the originals. I have replaced the surrounds on the 10-inch mid-bass drivers and the foam inside the compression drivers. The 18-inch woofers are the same as the originals and were also used in the first Imax systems, where usually 20 of them were deployed.
09-12-2024, 08:54 AM | #18 |
Rep 1,056
For those of you with sonos how do they still connect? I have 8 speakers and only 3 work. When the app updates it randomly chooses to have issues updating some speakers and slowly they stopped working. I can't even use the app anymore cause it wants to update a speaker but always fails. I think it's forced obsolescence so you have to buy newer ones. I just use spotify to force the few connected speakers to play.
I've even reset them to factory settings which used to work. I eventually gave up and will never buy another sonos product ever again. Their customer service is horrid and has provided no help. They have bluetooth and wifi yet you can only use them with their app, which is horrible.
08 M Coupe • Ceramic Black Fabspeed Headers • MCS 1WNR • Poly FCAB • Stoptech BBK • Vibra-Tech • Epic Tune • Apex EC7 • RPI Scoop • Eventuri • Stromung • Rogue X Pipe • Varis Diffuser • CF E92 GTS Wing • CF Roof
09-12-2024, 09:53 AM | #19 | |
Rep 1,003
