      08-23-2024, 06:54 AM   #1
R1wheelieforfun
Drives: 2005 BMW M3
Fs: 2005 bmw m3 6mt
2005 BMW M3 factory 6 speed manual transmission
For sale is my extremely well cared for E46 M3 finished in Silbergrau-Metalic over black leather with brushed aluminum trim. Purchased in September of 2019 with 119,235 miles. Clean MA title in hand with current MA state inspection.
Mileage: 135,536
VIN: WBSBL93445PN62641
More photos, documentation, or any other questions are available to be answered.
Big 3 maintenance (rod bearings, Vanos, subframe reinforcement) has been completed with supporting documentation from Wile Motorsport 3/24/2020.
Exterior:
Car is 19 years old and from what I can tell is original paint. Front end is showing its age with some pitting and chipping. There is one minor dent on the passenger side near the side grill (almost unnoticeable).
Car had a full decontamination wash and stage 1 paint correction as well as ceramic coating November 2022.
Interior:
Fantastic shape, no tears or stains in the leather. Rear seats are almost brand new. Arm rest is a bit worn. The steering wheel appears to be original and has some wear on the 9 and 3 O’clock positions. Headliner intact. All interior lights are functional as well as all gauges, dash lights, indicators, etc. functional. Heated seats work great. AC is ice cold; heat works great as well. Hardwired for radar detector. Dynavin N7 head unit with Bluetooth and Nav (no Apple Carplay)
Wired for amp and sub
Modifications:
Tune:
Kassel tune
-MAP conversion kit (specific for CSL airbox)
-Performance Tune
- SAP Delete
-Disable Post Cat O2 Sensors
-Enable shift lights
-Top Speed Delete
-Alter Rev Limiter to 8200rpm
- Full CSL Hardware/Firmware Conversion
Intake:
Turner Motorsport CSL replica carbon airbox
CSL Dipstick Relocation
Exhaust:
Agency Power Catless Headers
Status Gruppe Section 1 Un-Resonated
Status Gruppe Section 2 X-Pipe Resonated
Scorpion Muffler
Suspension:
Bilstein B-12 Pro Kit
Eibach Front Adjustable Sway Bar
Brakes:
Stainless steel lines
OE brakes/pads
Stainless clutch line
Wheels:
BMW OEM CSL Wheels
19x8 et47 front – H&R 20mm spacers with extended Lug nuts
235/35/19 Michelin Pilot Sport 4S
19x9.5 et27 rear – Apex 12mm spacers with extended lug nuts (NOTE: there is a small surface scratch on rear drivers side wheel)
265/30/19 Michelin Pilot Sport 4S
Maintenance Log:
June 2024:
New headlight covers
March 2024:
New front window switches (Left and Right)
Oil change kit
Front Zimmerman brake rotors
April 2023:
Comprehensive vehicle inspection by BMW specialty shop Wile Motorsport
Oil change kit (Wile Motorsport)
Remove and replace front lower control arm bushings BOTH sides
April 2022:
Oil change kit
Brake fluid flush
September 2021:
Oil Change Kit
New Battery
June 2021:
Windshield washer pump replaced
March 2021:
New throttle position sensors (front/rear)
New accelerator pedal module
Oil change kit
June 2020- 121,500 miles
Full Cooling System overhaul
OEM Radiator
BMW Water Pump and T-Stat
New Radiator Mount
New Fan Blade
New Fan Clutch
New Fluids
April 2020:
Oil service kit
Center Console Trim
Coin Storage
Center Console
Cup Holder
Exterior window trim pieces, gasket railing left and right
BimmerWorld Racing Pedal Kit including dead pedal
March 2020: 120,100 miles
FCP Euro BMW Brake Kit (Front and Rear)
Zimmerman Rotors, OE Pads
Bimmerworld E46 Subframe Reinforcement kit installed by Wile Motorsport
Rod bearings replaced including- oil pan gaskets, and engine mounts by Wile Motorsport
Bulletproof Vanos- Valve Cover Gasket set, VVT housing seal, VVT housing seal plate, bolts, Vanos pump disc by Wile Motorsport
Spark plugs x6
Timing Chain Guide Rail
Install new Bilstein street suspension, new shock bump stops, and shock/strut mount gaskets
Fuel Filter
Driveshaft flex joint
Drive belts
Diff Fluid flush
Brake fluid flush
New front left caliper
Oil service kit
October 2019:
Cabin Filter
Air Filter
PREVIOUS OWNER STATEMENTS, NO DOCUMENTATION:
Mileage 112k:
Valve Cover Gasket
Mileage 98k:
Diff fluid flushed- Castrol SAF-XJ
Trans fluid flushed- Pentosin MTF2
Power Steering Flush
OEM Fuel Filter Replaced
Valve Adjustment
Coolant Flushed
Spark Plugs Replaced - NGK 7415
Luk Clutch Kit, OEM Flywheel, shifter bushings
To be desired:
Front end bumper and fender flares show their age with rock chips and dings.
One scratch larger scratch on underside of front left bumper (cannot see from standing view)
Front windshield is original and pitted, as well as one tiny rock chip
Front fog lights are functional but pitted
Front A-Pillers both driver and passenger side were re-wrapped at some point prior to my ownership and the fabric does not quite match the headliner but looks fine
Arm rest worn but functional
Passenger side headlight needs new seal (leaks in touchless wash, does not leak in handwashing)
Side view mirrors showing their brown spots around the edges
Car comes with 1 key, the “BMW” lock button on the key does not work (the unlock and trunk pop does). I lock the car with the key in the driver door.
Last edited by R1wheelieforfun; 10-10-2024 at 08:00 PM.. Reason: Error in price header
mapster37426.50
