08-21-2024, 03:31 PM | #1 |
![]() ![]() ![]() 47
Rep 442
2006 BMW M3 Convertible
For sale is my 2006 BMW M3 Convertible 6 speed manual. Titanuim Silver exterior, Dove Grey interior. Clean title, no accidents. Title in hand, car is paid off. VIN# WBSBR93406PK10835 Some highlights: Turner Motorsports CSL Intake with HTE Tune Style 172 e60 M-sport wheels, staggered Full Status Gruppe exhaust header back H&R Sport springs with Koni Yellows Full vanos rebuild Valve adjustment Rod bearings done with ARP Bolts Cooling system rebuild Overall this car is in great condition. This is really a nice example of a final year M3. I have a pile of service records, and original window sticker. 2 keys. A few minor issues: Has a few rock chips on the front bumper and some small scarpes on the bottom of the bumper. Could easily be toughed up. Auto up window switches work intermittently. A couple small dead spots on the nav screen. Some accessories included: OEM wind diffuser w/storage bag OEM windshield reflector w/storage bag Eastwood stretch to fit indoor car cover w/storage bag Detailed modifications and maintenance : 106k Miles New Battery New Alternator Fuel Pump AUX cord hookup Battery tender hard wired 104k miles VAC rod bearings w/ARP bolts New oil pan gasket New OEM engine mounts New Continental DWS tires (roadforce balanced) HTE Performance remote tune OEM drivers front floor mat 102k miles Water pump / fan clutch / thermostat / ECS silicone radiator hoses & silicone overflow hose retrofit / Mishimoto aluminum radiator / fresh BMW coolant Full vanos rebuild: new Beisan o-rings and Teflon seals throughout, new OEM solenoid, new OEM vanos filter kit, VAC HD exhaust hub, Beisan anti-rattle kit installed, Beisan nylon upper timing chain guide, and Rogue Engineering stainless braided vanos oil feed line Adjusted valves and replaced: OEM spark plugs / valve cover gasket / OEM vanos crush gasket Power steering cooler E90 upgrade, custom reservoir relocation, fresh ATF Turner Motorsport CSL intake, matte carbon fiber; new silicone boots, modified dipstick, ITG Evolve foam filter, MAP sensor conversion, Turner Motorsport IAT kit, OEM CSL vent pipe and vacuum sensor pipe Kassel Performance CSL DME hardware / firmware conversion Turner Motorsport underdrive pulleys, Continental Belts 85-90k miles Full brake job front and rear: Centric high carbon rotors, Cool Carbon pads, parking brake adjustment ECS stud conversion Cabin air filter, OEM Hengst Rear trailing arm bushings, OEM rubber w/ poly ECS limiters Turner Motorsport rear sway bar w/ new links and bushings Fuel filter, OEM Advanced Fuel Dynamics E85 conversion Secondary air pump delete Status Gruppe headers, resonated section 1, Status Gruppe resonated section 2, Status Gruppe SCZA muffler Carbon fiber CSL style rear valance Koni Yellow shocks, H&R sport springs, OEM heavy duty strut reinforcement plates, ECS rear strut mount reinforcement plates, all new mounts and insulators, Ground Control street caster / camber plates Alignment done at BMW Motorwerks Transmission fluid (Redline D4) and differential fluid (OEM Castrol) E21 rubber transmission mounts w/cups Shifter rebuild, e60 M-sport shifter, new OEM ball socket bushing, new OEM hardware, Turner Motorsports poly mount bushings, F10 M5 OEM weighted shifter and boot retrofit New OEM convertible top relay Black kidney grilles, black side gills, new headlight clearshield, amber fog light clearshield New side marker lights / new front corner lights, smoked / clear front reflectors 3000k HID amber bulbs / amber running light bulbs Dealer programming for Canada style running lights (high beams), one press unlock both doors, and one tap three blinks turn signal European sliding center console tray, OEM Fluids Transmission fluid Redline D4 (every 30-40k miles) Diff fluid OEM BMW / Castrol (every 30-40k miles) Power steering Valvoline ATF (every 60k miles) Engine oil Liquimoly GT1 10w60 w/Cera-Tec (every 5k miles or once a year) Oil filters Mann or Mahle (every 5k miles) Coolant OEM BMW blue (every 100k miles) Oil filter torque 24 ft-lbs Drain plug torque 18 ft-lbs Wheels 95 ft-lbs torque for stud conversion Style 172 e60 M-sport wheels, staggered o F 19x8.5 et18 (-2deg camber) o R 19x9.5 et32 (+10mm spacer) Tires Continental DWS Performance All Season o F 235/35ZR19 o R 265/30ZR19 Private Sale, Contact Dan at 651-399-3384 I will not sell anything individually / part out anything. No trades. $19,500 or best offer. Last edited by Gnip Gnop; 09-04-2024 at 07:55 AM.. Reason: price reduction |
