02-25-2024, 11:41 AM | #1 |
Rep 21
F30 340i (base grey brakes, non M sport)
Hey everyone im looking to upgrade my braking power on my 340i with the base grey calipers. I believe that means i have the 340mm and 330mm rotors. I see this kit on ecstuning which i will link below and it comes with their V5 slotted rotors alongside EBC redstuff pads. Both front and rear.
I mostly want the car to have a stronger brake feel and be confident in that sense, I know upgrading the rears to 2 piston calipers would be smart but would this option from ECS work well too? https://www.ecstuning.com/b-assemble...4106797602skt/ |
02-26-2024, 05:56 AM | #2 |
Idiotic lifter of heavy stones...
1976
Rep 2,158
Drives: 2015 F31 325D M Sport touring
Personally I'd avoid any EBC pads; never had a good experience from them and I've used them a good few times now (Red & Yellowstuff)
ATE, Zimmerman, TRW discs with decent pads (Brembo HP2000s get good reviews, Ferodo DS2500s maybe, the Hawk pads seem to be well thought off too) and decent braided lines (HEL/Goodridge or similar) with decent fluid; you'll do well with that IMO
My car: 2015 F31 325D M Sport Touring in Glacier Metallic Silver - Keeping it OEM 'Plus'
Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298 |
02-26-2024, 02:14 PM | #3 | |
5923
Rep 10,306
- Prefer to retain the same rotors (size)? - Looking to have a more aggressive initial bite? |
02-26-2024, 02:19 PM | #4 | |
Rep 21
Honestly i want stronger brake bite/stopping power. I wanted 370mm rotors for the looks which is why i considered a full brake kit for around 3k from BMW but im thinking if i can manage without the looks of the 370mm and stick to 340mm i can just get m sport rear calipers and get 345mm rotors and keep the fronts the same. On top of that get new 340mm rotors for the front being drilled etc. and upgrade brake pads to ds2500's or something. |
02-26-2024, 06:37 PM | #5 | |
5923
Rep 10,306
BMW M Performance brake kit is a popular option and will almost certainly provide what you are looking for - if the budget permits. This kit does come with dimpled / slotted rotors. The pros and cons of dimpled rotors is beyond this discussion but it's helpful to mention that dimpled rotors were developed for much heavier vehicles. No measurable benefit in daily driving conditions. About brake pads: there is at least one community of proponents for each brake pads. However, the laws of physics do not change. If you prefer an aggressive initial bite, OEM M Sport pads are excellent but produce brake dust which is an indicator that brake pads are being "shaved" while preserving rotor life span. PS. There are other, more expensive options such as Brembo BBK and AP Racing BBK. These brakes are phenomenal and expensive as a result. |
02-26-2024, 07:58 PM | #6 | |
Rep 21
I would consider the M performance kit and was for a while. But everyone told me that the bigger rotors are almost only useful if you track the regularly, which I do not and never have. I might eventually but it wont be often. I hear that the OEM pads are the best bite but i heard a few people tell me that ds2500 pads are an upgrade and do produce alot of dust as a result but i dont mind that. Upon that I can get the rear brake calipers used so i get the 2 piston ones instead, and get slotted or drilled rotors for them, alongside rotors for the front calipers which would remain 340mm at that point. |
02-26-2024, 08:23 PM | #7 |
5923
Rep 10,306
From https://f30.bimmerpost.com/forums/sh....php?t=1721591
"Bigger rotors offer two advantages. - Better heat dissipation - Greater braking torque because of longer lever arm. Another way to think about it: less energy is needed to stop a spinning rotor closer to the outside of its diameter. It's the same principle of leverage. Try removing a stubborn lug nut with a 5" wrench or a 30" wrench." The question is whether the driver (daily driving) will notice any difference with 340mm or 370mm rotors in the front. The difference is perhaps insignificant. |
02-28-2024, 09:18 AM | #8 |
Rep 603
I recommend to go with EBC YellowStuff instead of RedStuff.
Upgrade to larger rotor front and rear is quite a big job in work and price. Be aware that there are different types of rear 345 rotor depending on the emergency brake setup. If you choose to change the rotor make sure to get the right rotor and caliper for a 340i! You also need to change the dust shield and proper coding is needed for each brake setup. The YellowStuff will give you a very good cold and an even better hot braking then OEM and Redstuff. RedStuff is a great pad with lower and less agressive dust then OEM and YellowStuff. YellowStuff has better friction then RedStuff.
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
02-28-2024, 09:24 AM | #9 | |
Rep 21
02-29-2024, 02:33 AM | #10 | |
Rep 603
However you can still go with the YellowStuff pad for the M-Performance Kit. If you want to deep dive into the brake toppic: https://f30.bimmerpost.com/forums/sh...d.php?t=858607
03-12-2024, 10:04 PM | #11 | |
Rep 99
03-13-2024, 12:53 AM | #12 | |
1976
Rep 2,158
Know plenty of folk with road going track focused cars that have run Blue stuff and nothing but issues, on road and light track work... They're better than a road going pad for light track, but that's about it...
