BMW M3 and M4 - The Icons
Classifieds Sponsors Classifieds Suspension / Brakes / Chassis / Spacers
      02-19-2024, 11:55 AM   #1
IND-Distribution
IND-Distribution's Avatar
9587
Drives: G82 M4 / G87 M2
IND | MMR Performance G8X M3 / M4 Lowering Spring Set
The MMR Performance Lowering Spring Kit is one of our best-sellers. Little wonder, as they've earned a reputation for delivering the perfect blend of improved handling, enhanced looks, yet all without sacrificing ride quality.
The drop in ride-height makes a huge difference to the handling characteristics: by lowering the G8X's center of gravity, it reduces body roll for better dynamics, whilst maintaining the ride quality and comfort of your car.
Thanks to the carefully selected progressive spring rates the ride-quality remains unaffected and is actually nicer to drive at slower speeds. But push-on through the corners and the G8X chassis really comes to life, making it feel lighter, more direct and with significantly sharper turn-in.
Meanwhile, the car's appearance is transformed. By getting rid of those nasty wheel arch gaps, it'll look just how it should have come from the factory!
Go lower or stiffer than these MMR Springs and your car will bounce and crash as the dampers are mismatched to spring-rate, and the springs themselves run out of travel.
Finished in MMR Metallic Grey, the Lowering Springs are developed to be fully compatible with cars fitted with either static or Adaptive M adaptive dampers. A must-fit for any G80 M3 or G82 / G83 M4!
Product Details:
  • Carefully optimized spring rates for improved driving dynamics
  • Designed to be compatible with Adaptive M and static factory dampers
  • Lowers vehicle by 30mm front | 30mm rear (RWD) and 25mm front | 20mm rear (xDrive)
  • Powder coated in MMR Metallic Gunmetal Grey for a durable finish
  • Fitments for RWD and xDrive
The MMR Performance G8X M3 / M4 Lowering Spring Set may be viewed at the following link to our website:
https://ind-distribution.com/product...ing-spring-set
Please contact IND by phone or email for more information or to place your order.
866.963.4520 | info@ind-distribution.com
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
g80
