02-06-2024, 02:59 PM | #1 |
Rep 36
Drives: BMW 335d xDrive
335d M-Sport brakes replacment
Hi all,
when the summer hits i wanna change the brakes(Disc and Rotors(Disc's)) on my car, i think only the front ones but maybe the rear's aswell, now there are allot of options, i'm not tracking the car every day but i have a 335d witch i pretty danm quick so i wanna have some good brakes, little count list of what i need OEM: Pads €260 Disc €362 times 2 so €724 total 1036 some other stuff about €50 and dont get me started about the labour of the (S)dealer if i go aftermarket route with zimmerman (Wich i believe is the oe manufacturer of BMW qoute me if i'm wrong please!) and ebc yellow stuff Zimmerman sport z €264 for 2 EBC yellow stuff €246 (I could go way cheaper with ATE pads that are around 120 ish) Sensor €12 total of €522 Why is there such a big diffrance? and is DIY route the smarter way? help a fellow BMW fan out |
02-06-2024, 05:22 PM | #2 |
Rep 99
Some great advice from the folk in these threads:-
https://f30.bimmerpost.com/forums/sh....php?t=2024715 https://f30.bimmerpost.com/forums/sh...ghlight=brakes I need new front discs and pads and have just ordered Brembo 09.C394.13 two piece front grooved/sotted discs with correct OEM BMW pads for the M Performance discs. Nearly went ATE blank discs with their Ceramic pads, these and other recommendations in above threads from more experienced guys than me hope that helps! |
Freakstar5064.00 |
02-07-2024, 09:55 AM | #3 |
Rep 1,117
Stick to genuine BMW discs and pads if you want an easier and squeal free life.
Freakstar5064.00 |
02-10-2024, 10:19 AM | #4 |
Rep 226
Do you have the OEM BMW M sport brakes already ? (With the blue calipers)
In that case, all OEM parts are fine aside from the stock brake fluid and pads which are horrendous. Just a set of good pads and brake fluid will do. EBC Yellow is ok for street use (you could go for Endless if you want even better performance but they're more expensive and squeel a little bit when hot), and then just use any uprated brake fluid. Castrol SRF brake fluid is really good and will never reach its limit. |
