12-12-2023, 06:22 PM | #1 |
2563
Rep 1,927
Oil analysis of bmw's tpt 0w30 oil @ 4000 miles
Just got my results from blackstone, engine had 5200 miles on it at the time of the oil change and the oil had 4000 miles on it. I'd like to see what the oil looks like after 10000 miles as bmw recommends but not sure i want to go that far between changes. Will be doing my own oil change between the free ones from bmw.
I put in motul specific ll-01 fe 0w30 this time and will sample that right before i go in for the free oil change and compare it to bmw's tpt oil.
11
blackops23486.00 CCM11285372.50 nalnass118.50 BrendanZ0402283.50 GrannyShiftG801295.00 AWDSOME629.50 eugenebmw1479.00 SE7EN335330.00 M4Tejas788.00 FSociety3812.50 DataNerd96.00 |
12-13-2023, 09:18 AM | #2 |
Rep 880
So 4000 miles on OEM oil and viscosity has already thinned out below spec ?
And BMW wants 10,000 miles between oil changes lmao
2022 G80 M3 6MT
2020 G20 330i xDrive 2011 E90 335i xDrive 1996 E36 318i |
12-13-2023, 01:03 PM | #3 |
Discharged
140
Rep 160
Viscosity would probably go back up by 10K miles from oxidative thickening.
Past-18 F80 M3 Comp, 11 E90 M3 Comp, 97 328is, 95 E36 M3, 89 325ix
12-13-2023, 02:38 PM | #5 |
Rep 880
motul 8100 xcess gen2?
2022 G80 M3 6MT
12-13-2023, 03:35 PM | #6 |
2885
Rep 2,614
Drives: 2024 M4 Convertible
12-13-2023, 04:43 PM | #7 |
Rep 358
Man that’s wild to me they recommend a 0W. I get most modern cars do, but most performance oriented applications are still using 5/10/15. I think when I had my supercharged coyote Mustang Ford recommended 5w50.
2015 VW GTI (446whp/414wtq)
2024 M3 Comp xDrive |
M4Tejas788.00 |
12-13-2023, 09:04 PM | #8 |
2563
Rep 1,927
Wouldn't that depend on bearing clearances?
12-13-2023, 09:08 PM | #9 |
Rep 358
Important but heat is equally important. At least on the Coyote you’re taking a high compression engine and shoving extra air down it making a ton more heat so the thicker oil pays off.
12-13-2023, 09:24 PM | #10 |
5460
Rep 5,153
forcefed
Any tune on that engine? Your analysis seems to reinforce our suggestion to change oil every 5K miles for best protection. I suspect that your Motul Specific will yield a similar wear and dilution profile. I would keep to the 4-5K OCI instead of using thicker oil. Don’t get me wrong…Motul 8100 is great stuff, but I wouldn’t switch to it just to combat dilution.
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
12-13-2023, 09:35 PM | #11 | |
2563
Rep 1,927
Would be nice to have some more oil analysis from others.
12-14-2023, 08:17 AM | #12 |
2022 M4 Comp Xdrive
1015
Rep 1,538
GrannyShiftG801295.00 |
12-14-2023, 08:18 AM | #13 |
2022 M4 Comp Xdrive
1015
Rep 1,538
12-15-2023, 11:54 AM | #15 | |
Rep 320
No problems. I did change my oil though as interval is 19k miles here. |
forcefed2562.50 |
12-15-2023, 02:20 PM | #16 | |
2563
Rep 1,927
Mine are mostly short trips.
12-15-2023, 02:29 PM | #17 | |
Rep 320
I tried to give it a good break in though i did redline it once or twice by accident. Lots of cycles up to 5500 limit. Usual BMW oil 0W30. No major extremes of temps in uk. |
forcefed2562.50 |
12-15-2023, 03:17 PM | #18 |
1479
Rep 475
That what I heard too. Today’s advanced engines are built with much tighter tolerances than their predecessors. The clearances between the crankshaft journals and main bearings are tighter, for one. This is purposely done to allow modern engines to use lower-viscosity motor oil, like 0W-30. Thicker oil may not flow quickly enough (Canada winter cold start). The oil won’t form a consistent lubricating film, allowing metal-to-metal contact and wear. Engine was designed specifically to use a lower-viscosity oil, in this case 0W-30. Its lower viscosity allows it to flow faster and fill the tiny clearances between parts, leading to a durable, consistent lubricating film.
Not only that, but the engine will waste energy pumping the thicker oil, reducing fuel economy. Since thicker oil doesn’t transfer heat as well as thinner oil, operating temperatures will increase, possibly leading to accelerated chemical break down (called “oxidation“) and harmful sludge and deposits Last edited by eugenebmw; 12-15-2023 at 03:43 PM.. |
12-15-2023, 03:22 PM | #19 |
1479
Rep 475
12-17-2023, 02:04 PM | #20 |
Rep 168
Drives: G80 M3 GTP 6MT
That KV100 is alarming! Good thing the S58 doesn’t get too hot even at the track lol. I’ll be putting motul 5w40 either Xcess Gen2 or Sport when the free maintenance runs out. The redbull bros drift team runs 15w50 300v in their cars FWIW and their rod bearings looks fantastic
Dawgz1015.00 |
12-18-2023, 09:22 AM | #21 | |
Rep 134
Dawgz1015.00 BrendanZ0402283.50 |
12-18-2023, 04:05 PM | #22 | |
Rep 984
2022 M3 XDrive - Full Race Turbos - BMC Filters - MAD Catless downpipes - MAD single midpipe - BM3 Flex Fuel Kit - Paul Johnson Flex Fuel - XHP - MPHAS - EBC Bluestuff - PS4S
2023 IX M60 2018 Lotus Exige Sport 410 - Harrop TVS1900 Supercharger - HKS Intake - Larini Headers - Simply Sports Cars Custom Tune - Ohlins TTX - Ferodo DS3.12 - Yokohoma AD09 |
