12-06-2023, 07:18 AM | #1 |
Rep 31
Air Recirculation Always ON - New G05
I just picked up a new G05 (was built Mar2023 but the dealer lost it in their inventory until last month). It is the 2020-23 model (i.e. not the new LCI)
I have managed to code everything the same as my 2020 740i but one thing keeps not working... the air recirculation always on In the G11 740i coding UMLUFT and UMLUFT-with-AC to be always on was a doddle... and the only time it ever turns recirc off is when I use the MAX DEMISTER on the front windscreen. Perfect In the G05 X5 even though the UMLUFT settings are all the same as the G11, the air recirc light goes off after maybe 3-4 minutes and has to be turned on again. I have set UMLUFT memory to AKTIV (which should make it remember... right?) but to no avail. Nothing I seem to do gets the G05 to be like the G11 and keep the air recirc on. Does the G05 have some other setting somewhere that keeps overriding? |
12-06-2023, 07:26 AM | #2 |
4736
Rep 8,812
Drives: eVeRyOnE mAD!
it’s not advisable to keep air recirculation ON constantly. per its programming, it will automatically turn off air recirculation
12-06-2023, 07:28 AM | #3 |
Rep 31
It should always be the vehicle owner/driver's choice.
I've had it this way in every car I've owned for two decades... so an answer like that doesn't deal with the question. I've never had a problem with condensation inside my air conditioned vehicle - so the quote in the image is just nonsense. What gets me is that several other people have asked this question and all they get is these moralistic judgemental responses that don't resolve the problem. If they (like me) want their car to work a particular way, why don't we just answer the question being asked? |
12-06-2023, 08:21 AM | #4 | |
4736
Rep 8,812
that screenshot from the manual answers your question and gives a clear indication how BMW programmed its vehicle to behave. to be clear, there’s no setting that’s overriding your coding. there is no “problem” as you claim. it’s behaving as programmed. coding, for all intents and purposes, goes against that programming. be happy that you can even code; newer models are completely blocked from coding. while this particular one isn’t working as you would like, being a baby about not getting your way isn’t the answer either. FWIW, the coding you performed isn’t universal across all models even though it looks the same. surprised you don’t seem to have given that any thought. this is something you need to take up with tech support of the coding software you use. it could simply be a matter of “too bad, so sad”, or maybe you’ll get lucky and they’ll include this feature in an update |
