BMW M3 and M4 - The Icons
Technical Sections Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      11-09-2023, 07:47 PM   #1
wowwitsgau
wowwitsgau's Avatar
Drives: S2000 x2, 2022 M3 Comp
Supersprint Midpipe + Akrapovic Rear Section Compatibility
I'm having an issue whilst trying to install a Supersprint midpipe combined with an Akrapovic rear section; the problem is that the two pipes of the midpipe are spaced closer together than the Akrapovic (which has the same spacing as the stock exhaust). If I slide the coupler on one of the pipes, the other pipe won't be aligned.
Anyone have any ideas on how I would be able to go about fitting these two exhaust components together?
TIA
g80
