BMW M3 and M4 - The Icons
Classifieds Sponsors Classifieds Engine / Drivetrain / Exhaust / Bolt-ons
      10-06-2023, 10:04 AM   #1
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
**the new** mishimoto 2021+ bmw g8x m3/m4 3.0l s58b30 open airbox performance intake
BEST DEAL!!
The BMW G8X M3 and M4 are automotive engineering masterpieces and Mishimoto is committed to highlighting every ounce of their potential, including their auditory prowess. This Mishimoto open airbox performance intake is designed to unleash the sound of power from the S58 under the hood of your 2021+ BMW G8X M3/M4.
The open-element design of this intake is fine-tuned to allow your turbos to breathe freely and deliver an enhanced and aggressive engine note. Get ready to roll down the windows, punch the throttle, turn heads, and ignite your passion for driving. With this intake installed, you'll get to revel in the sound of turbo spool and BMW's legendary induction sound with every RPM.
The Mishimoto 2021+ BMW G8X M3/M4 open airbox performance intake is engineered as a complete bolt-on kit and includes everything you need, making installation a breeze. The durable steel heat shields are powder coated in a sleek micro-wrinkle black finish to withstand the harshest environments while adding to the aggressive styling of the G8X engine bay. Two high-quality washable oiled filters protect your S58's sensitive internals from dust and debris, while the rotational-molded intake tubes isolate the intake air from engine bay heat. Like all Mishimoto BMW products, this intake is backed by the Mishimoto Lifetime Warranty for as long as you own the vehicle.
If you're ready to unleash the true sound of your 2021+ BMW G8X M3/M4 and experience the thrill of auditory performance, then it's time to upgrade your driving experience with Mishimoto's open airbox performance intake.
PRODUCT FEATURES
Direct fit for 2021+ BMW G8X M3/M4 with 3.0L S58B30
Greatly enhances turbo spool and induction sounds
Open filter elements and black powder coated heatshields for a sleek and aggressive look
Installs in less than 1 hour with no need to remove the front bumper or undertray
Steel heatshields deflect heat while allowing maximum flow and sound
Rotational molded tubes isolate intake air from engine bay heat
CNC-machined aluminum connectors for maximum durability and a leak-free install
Passenger-side turbo inlet improves flow and durability
Washable oiled filters can be cleaned and refreshed using available filter re-oil kit
Patent Number 11,506,157 B2
PURCHASE INCLUDES
(1) Driver-Side Intake Heatshield Assembly
(1) Driver-Side Air Filter
(1) Driver-Side Intake Tube Grommet
(1) Driver-Side Intake Tube Coupler
(1) Driver-Side CNC Quick-Disconnect Fitting
(1) Passenger-Side Intake Heatshield Assembly
(1) Passenger-Side Air Filter
(1) Passenger-Side Intake Tube Grommet
(1) Passenger-Side Intake Tube Coupler
(1) Passenger-Side Aluminum Turbocharger Outlet
(5) CNC-Machined Airbox Peg Kits
(4) Stainless Steel Worm Gear Clamps
Mounting Hardware
https://x-ph.com/sale/
Phone number 702-494-9435
      10-30-2023, 06:56 AM   #2
mike@x-ph.com
      11-16-2023, 06:42 AM   #3
mike@x-ph.com
      12-18-2023, 06:45 AM   #4
mike@x-ph.com
      01-08-2024, 08:33 AM   #5
mike@x-ph.com
      01-25-2024, 07:36 AM   #6
mike@x-ph.com
      02-13-2024, 06:52 AM   #7
mike@x-ph.com
      03-01-2024, 06:49 AM   #8
mike@x-ph.com
      03-21-2024, 06:36 AM   #9
mike@x-ph.com
      04-22-2024, 10:47 AM   #10
mike@x-ph.com
bump
g80
