10-02-2023, 08:48 AM | #1 |
Rep 881
What is this nasty scraping sound when braking
https://youtube.com/shorts/7PdYrxHNW...H-ihL8Ip6UVbuB
Anyone know what this sound is? It seems to be coming from the back left it started when I was on track
2022 G80 M3 6MT
2020 G20 330i xDrive 2011 E90 335i xDrive 1996 E36 318i |
10-02-2023, 10:52 AM | #2 |
Rep 686
Can't hear that clearly but it's somewhat common for a little rock to get stuck between the rotor and shield.
2011ninja3412.50 nearwater4me1918.50 |
10-02-2023, 11:32 AM | #3 |
6920
Rep 3,277
Drives: E46 M3 Coupe/G80 M3CX
You have a semi truck stuck in your wheel.
10-02-2023, 01:02 PM | #4 |
Track Rat
1760
Rep 403
Check your rear brake pads immediately. I really hope that it's not the case, but it could be that the rear pads have worn down to the backing plate which is now in contact with the rotor. If this is not the case, congratulations, and you really should be monitoring the pads closely anyway if you drive your car on track.
A rock (or something) trapped between the rotor and the dust shield usually results in a constant scraping sound, not just when the brakes are applied. If you are not confident in your own self diagnostic abilities then take it to a shop ASAP, and good luck.
IOMG // Full Tartufo Leather // MP HAS // Vorshlag Camber Plates // SS Brake Lines
10-02-2023, 01:23 PM | #5 | |
6726
Rep 6,755
Edit, it wasn't you, but you did post in the thread... https://g80.bimmerpost.com/forums/sh...highlight=rear And I was overly drastic. It was 12k miles. But someone else posted they smoked them in 11k. Yikes. |
10-02-2023, 01:26 PM | #6 |
Rep 924
Ive gone to the backing plates on track on my fronts and nursed it 50 miles home on country back roads doing a lot of engine braking to keep off the brakes and minimize rotor wear..my rotors were fine.
2023 F90 M5
Retired - 2021 G82, 2019 440xi, 2020 X7, 2019 X5, 2013 F10, 2010 F10 |
10-02-2023, 02:48 PM | #7 |
Track Rat
1760
Rep 403
Hey BB it's been awhile. I hope all is well with you. In my case it was the rears that went to the backing plates. Surprise, surprise! I managed to make it nearly all the way home (110 miles) on the Florida Turnpike without once touching the brake pedal, but then ran into total blockage due to a major accident somewhere ahead in the last 8 miles. Stop and go for the rest of the way. Very painful. I did find someone to cut the rotors though.
10-03-2023, 01:52 PM | #9 |
Track Rat
1760
Rep 403
Sorry to hear this. Rather expensive rear rotors could be in your near future.
If you continue to track your car you need to watch the rear pads like a hawk. I mean several times during the day. And especially if you use OEM brake pads. You will be amazed at how quickly they wear away. When I was using OEM pads I never had a set of rears last more than a single day. In fact several times they didn't make it a full day. Hence my drive o' shame back home.
10-03-2023, 03:19 PM | #11 |
4275
Rep 2,496
Drives: 2018 F80 M3 CS,2017 F87 LBB M2
perhaps traction control intervention
2018 F80 M3 CS
2017 M2, LBB, DCT, exec, car play, MPE, diffuser 2011 E90 M3 ZCP Past: E90 328i, F10 535i, F80 M3 (murdered) |
nearwater4me1918.50 Skyscraper2229.00 |
10-04-2023, 06:14 AM | #12 |
Track Rat
1760
Rep 403
It has nothing to do with TC intervention. I have driven these cars with with and without TC turned on and the results are the same. When these cars first came out the only source of brake pads was BMW and I bought 9 sets of rear pads so that I could drive my car on the track.
I addressed this in another thread. https://f30.bimmerpost.com/forums/sh....php?t=2045028
10-04-2023, 09:05 AM | #13 | |
Rep 881
2022 G80 M3 6MT
10-04-2023, 10:53 AM | #14 | |
6920
Rep 3,277
10-04-2023, 01:34 PM | #15 | |
Rep 279
How long is the track/s you're using? How fast can you get there? How many hours/minutes are you on track in a track day? How many minutes each session is? Thanks |
10-04-2023, 01:43 PM | #16 |
6726
Rep 6,755
10-04-2023, 02:27 PM | #17 |
Rep 881
these are the pictures of my rear pads and rotors
lasted 5.5 track days
2022 G80 M3 6MT
10-04-2023, 02:48 PM | #18 | |
Rep 924
Ive been off track for a while, been occupied with other priorities. Still holding on to the G82, though I have tried to find a reason to get something else, cant get excited enough to sell it..Especially with mine having ID7. Had to pull off the cobalts since my wife was tired of driving a freight train around town....but otherwise all good my man!
2023 F90 M5
10-04-2023, 03:47 PM | #20 |
6920
Rep 3,277
10-04-2023, 04:48 PM | #21 | |
2571
Rep 1,935
Rear pads are $14 https://www.rockauto.com/en/moreinfo...=1684&jsn=1405 buy a dozen sets and swap them every track day.
10-04-2023, 06:16 PM | #22 |
Track Rat
1760
Rep 403
I continue to use the stock rotors for now. I use Cobalt Racing Brake pads and have for about 1 1/2 year. I get about 6-7 track days out of the rears, and about 11-12 track days out of the fronts. I love the way they perform, and the wear is acceptable to me.
Most of my driving is done at Sebring International Raceway which is 73 years old, 3.7 miles in length, and alternates between asphalt and 81 year old concrete. It was built as an Army Air Force Base in WWII. 3 long straights and 17 turns with very heavy braking zones. My top speed there is 140-145. The average day is made up of 6 sessions of 30 min each. Sometimes more, sometimes less conditions permitting.
